- Mar 31, 2010
Hi guys, I'm finally up to the stage of over clocking my system. I've already got the CPU up to 4Ghz last night for the first time for around 10 minutes or so. I'm not really sure whether I'm doing the over clocking right or not though.
After over clocking last night, I decided to downclock to stock speeds that I was sitting on before overclocking i.e. my memory was at 1066Mhz, 2.8Ghz (before turbo of course) for CPU. After playing around with standard Gigabyte overclocking GT6 program or whatever it's called... I suddenly noticed that when you overclock to the Gigabyte presets, sure it changes the base clock but I think it leaves all the other settings auto and for the first time today I noticed that my DRAM voltage was at 1.7v+! when I overclocked to the highest the GT6 program will go i.e. 3.36Ghz. After seeing those DRAM voltages I immediately crapped my pants because I had overclocked to 4Ghz last night although in BIOS as the Gigabyte prog as I said, doesn't go that high but I didn't change any of the other settings from auto
so I'd hate to imagine the sort of voltages I was getting on the memory!!!
Are you supposed to switch all the auto options to off and set everything manually because I don't see how leaving stuff on manual will give us voltages that don't go to ridiculous levels!
P.S. My specs are:
i7 930
X58A-UD3R
G-Skill F3-12800CL9T (9-9-9-24 1.5V)
P.P.S. is there any chance that I damaged anything last night? How would I tell if I did?
UPDATE: When I reduced the memory multiplier to 8 or 6 or whatever the lowest setting that my mobo has, the uncore multiplier to the lowest and all the QPI to the lowest... the computer wouldn't turn on... kept turning on for a bit and switching off... had to reset the CMOS. (I realised that overclocking through the standard Gigabyte overclocking thingy is... um... not the best way to go as you can see above... kinda freaked out by the whole thing actually) which is why I'm trying to do it all through BIOS exclusively now.
![Shock :shock: :shock:](/forums/images/smilies/icon_eek.gif)
P.S. My specs are:
i7 930
X58A-UD3R
