- Mar 31, 2010
- Thread Starter
- #21
Try this.
CPU Multiplier: 19*200bclk OR 20*190bclk
vcore 1.34v
qpi/vtt 1.31v
dram 1.5 and 999 24 auto timings
leave the rest on auto
If that stable...then try to reduce vcore bit by bit.
When you get to know more...then start to play with other settings.
What CPU cooler do you have?..... i7-930 runs pretty hot above 4GHz.
What is your goal for this overclock?
Ok, will do.
My aim is as high as possible at reasonable temps. By reasonable I would prefer to have the CPU running at below 70 in FSX during summer (I'll probably have to downclock about 200mhz from whatever I get it up to right now for summer but we'll see). It's currently running at 60 or so, so I'm sure I can have it set to around 4.2 or similar, but unfortunately I don't want to run Prime95 at 4.2 @ >75c temps for long periods of time to test stability so I don't know if I'll be able to go that high. I'll be decently happy with around 4, @4.2, I'd be ecstatic.
Cooler is Megahalems Rev B.
UPDATE: Ran Prime95 for 1 hour and 15 minutes @ 1.215v QPI/VVT, 1.25v vcore & 200x19 and no crashes so that one off bluescreen was possibly just that... a one off.
I then started 200x20 at the setting recommended by SamSaveMax i.e. 1.34v for vcore (mine was slightly above 1.34 as there wasn't a 1.34v dead) and 1.31v for qpi/vvt (once again... slightly above as 1.31 exact didn't exist)... seemed to run fine although at 76 degrees which was unpleasant. Opened my window and switched the heater off to get the temps below my comfort zone of 75 and as close to 70 as possible... ran tests for around 20-30 mins at those settings then reduced both by 1 notch and repeated until I got down to 1.325v vcore and 1.255 qpi/vvt. This was stable in Prime95 for 40 odd minutes. Then reduced vcore 1 notch as I had already tried 1.325 and qpi/vvt at 1 notch above the sweet spot of 1.215v @3.8Ghz but crashed BSOD'd after 20 mins literally seconds before I was about to turn it off and reduce vcores once again. So looks like those are my final overclock settings. I don't think there's a point going to 4.2 as the temps are already in the 70s... low 70s with an open window and mid 70s with the heater on. I don't much want to go to above 80. So voila... I'm happy for now. Will do a longer Prime95 test at these settings as well as a memtest, which I haven't done up to now... but not tonight.
