- Nov 29, 2012
- Los Angeles, CA
I have a post over on Reddit, too, but it seems no one's on currently and was hoping maybe you guys would be alive here. I just realized there was a specific forum for AMD GPUs and thought it'd be better to it here. "xpost" no longer active; has since been deleted.
This is my first time overclocking anything, so!
Just read from my purchase on Newegg that the core clock is 880 MHz. When I opened Afterburner, I'm pretty sure it was at 850 to start.
i5-3570K @ stock
MSI 7950 TF3 @ stock
Tried overclocking 7950 using Afterburner
+20% power, 1000/1575
950/1500
+0% and 850/1250
+20% and 900/1350
Should I be worried about the lowered physics (and thus combined) score(s)?
+20% and 950/1400
Ran Furmark @ 900/1350
+20% and 900/1350
Now... I'm confused...
+20%, but 850/1250 (stock)
+20% and 875/1275
Quite the jump for such a small increase. Hm...
I hit "Reset" in Afterburner and it turns out stock speeds are 880/1250. So, underclocking the core by 5 MHz and overclocking the memory clock by 25 MHz gave me an increase in score of about 2000?! That sounds ridiculous!
+0% and 890/1290 (had reset to default, forgot to put +20%!)
+20% and 895/1295
+20% and 900/1300
+20% and 950/1350
+20% and 925/1325
+20% and 925/1300
+20% and 920/1300
+20% and 915/1300
+20% and 900/1300
It seems that 900/1300 is a good stable point for me. With the errors occurring at a core clock as close as 915, it may be best to not try for 901-914 at this point.
Inquiry: I do wonder, though, even with all cards being uniquely different in terms of overclocking potential: How is it that I am so far what most can do without any voltage tweaking (e.g. 1050/1550)? I can only really go 20 MHz past my card's stock core clocks, which seems ridiculously low. Further, though, it also seems weird that even though I can barely push my clock speeds (core/memory) any great length past stock, I obtain scores far higher than shown in guides regarding this card when they would overclock it to 1000+ MHz core/1500+ memory and with voltage increases as well.
It seems I jumped the gun...
ERROR! ERROR! ERROR!
Fixed issue by going down to 890/1275. Played BF3 for 30 minutes on "Ultra" with a slight increase in FPS from stock settings (from 40, give or take a few -> 50, give or take a few). Can I really not overclock this card?! Only 10/25 more than stock speeds... there's gotta be something wrong.
i5-3570K @ stock
- 3DMark11 Score: P7923 (Composition: Graphics: 8276, Physics: 7214, Combined: 6763)
- Doing this, tried to run 3DMark 11. It loads up, then I go back to desktop with a blown up screen (think, using magnifier on the screen), but it is still running in task manager and CPU/GPU are being used. I can't click on any windows or anything, as if I'm still in the program, just not seeing their little visual demo they use. Should I just let it run anyway?
950/1500
- Same results as above
+0% and 850/1250
- Runs perfectly and normally
+20% and 900/1350
- Success! New 3DMark11 Score: P8782 (Composition; Graphics: 9751, Physics: 6938, Combined: 6522)
- Max temperature: 53-54 C (varies between the two depending on temperature monitoring program used)
+20% and 950/1400
- Same problem as above
- Score: 3600
+20% and 900/1350
- Turns out it isn't stable
- Mouse disappearing on screen
- Lockup when loading up GPU-Z
- Display lost signal, computer was still running, required illegal shutdown
- 3DMark11 Score: P9962 (Composition; Graphics: 11724, Physics: 6994, Combined: 6685)
+20% and 875/1275
- Run 1: 3DMark11 Score: P10081 (Composition; Graphics: 11942, Physics: 7002, Combined: 6682); Max temperature: 55 C
- Run 2: 3DMark11 Score: 10073 (Composition; Graphics: 11945, Physics: 6987, Combined: 6659); Max temperature: 55 C
- 3DMark11 Score: P10198 (Composition; Graphics: 12147, Physics: 7026, Combined: 6686); Max Temperature: 55-56 C (depending on temperature monitoring program used)
+20% and 895/1295
- 3DMark11 Score: P10229 (Composition; Graphics: 12199, Physics: 7042, Combined: 6679); Max temperature: 55-56 C (depending on temperature monitoring program used)
- Furmark Score: 3600 (Benchmark Preset: 720; AA: Off); Max temperature: 54 C
- Furmark (1080p) Score: 2813(Benchmark Preset: 1080; AA: Off); Max temperature: 58 C
- Furmark (User-Defined) Score: 2725 (1280x720; AA: 2x); FPS: 45; Max temperature: 58 C
- Furmark (User-Defined) Score: 1397 (1280x720; AA: 4x); FPS: 23; Max temperature: 59 C
- Furmark (User-Defined) Score: 612 (1280x720; AA: 8x); FPS: 11; Max temperature: 59 C
+20% and 900/1300
- 3DMark11 Score: P10273 (Composition; Graphics: 12270, Physics: 7026, Combined: 6726); Max temperature: 56 C
+20% and 950/1350
- ERROR: Unable to run test; shows error (hastily clicked out and didn't write down)
+20% and 925/1325
- ERROR: Unable to run test [see error here: (1)]
+20% and 925/1300
- ERROR: Unable to run test fully [see error (2)]
+20% and 920/1300
- ERROR: Unable to run test fully (same as error "1")
+20% and 915/1300
- ERROR: Unable to run test fully; "application lost exclusive access"
+20% and 900/1300
- 3DMark11 Score: P10279 (Composition; Graphics: 12302, Physics: 7012, Combined: 6702); Max temperature: 51 C
- Fired up a game of BF3 while running 900/1300. A few minutes in, crashed. [expletive].
