- Sep 29, 2002
- Sacramento
I just installed my new P4PE and I was just settling in to test it , and the new audigy 2 platinum card, when wierd things started.
First the sound started going low and then it stopped altogether....out of the speakers,(4.1's)
then the puter stopped, I rebooted, and it did it again...... then it happened again, and I left it alone for the night. Got up today , booted it, then about 3-4 minutes into checking the settings, it died altogether. I hit the reset switch and it would not boot. I tried removing a memory stick, and it started to boot again, but stopped imediatly, then I got a HOT proscessor warning......would not boot, then nothing. please let me know that this is a power problem..... I am off to look into the chieftec cases with the 420w power supply, as that is within my budget at the moment........I hope I didnt burn the proscessor up! I put in a 1.8 proscessor, and it still would not post or boot...... this tells me that I am hopefully right....on the laptop till new one gets here......
P4PE 2.53
geforce 2 200 at present
radeon 9700 on the way!
audigy 2 platinum
heatsink was blowing air fine, in fact, I had put the stock fan on and it was working good....but things died , slowly and not all at once, could the motherboard have had a short, and ate everything slowly? thanks for the fast answer
P4PE 2.53
audigy 2 platinum
