Hello,
My brother has the following PC and it will not boot. It turns on for a second then completely powers off. No post beeps or flashing lights.
1 Intel Pentium 4 650 Prescott 3.4GHz LGA 775 84W Single-Core Processor Model BX80547PG3400F - Retail
Item #: N82E16819116196
1 ASUS P5N32-SLI Deluxe LGA 775 NVIDIA nForce4 SLI Intel Edition ATX Intel Motherboard - Retail
Item #: N82E16813131564
1 Pioneer 16X DVD±R DVD Burner with 2X DVD-RAM Read Black IDE Model DVR-110DBK - OEM
Item #: N82E16827129164
1 SONY Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
Item #: N82E16821103116
1 CORSAIR XMS2 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4300) Dual Channel Kit Desktop Memory Model TWIN2X1024A-4300C3PRO - Retail
Item #: N82E16820145558
1 Antec TruePower 2.0 TP2-550 EPS12V 550W ATX12V SLI Certified CrossFire Ready Power Supply - Retail
Item #: N82E16817103932
1 COOLER MASTER Wave Master TAC-T01-E1C Silver All Aluminum Alloy ATX Mid Tower Computer Case - Retail
Item #: N82E16811119023
I know this machine is quite old. It was purchased December of 2005. We have had another issue with this motherboard causing it not to post in the past. We sent it to ASUS and it took them over two months to send us back a replacement. They hinted at the fact that they do not have any more replacement boards for this mobo. When we got it back, it worked fine for a few months with all of these components. Now this is happening.
For this issue, we ordered another power supply from newegg but the same issue occurs. We are planning on returning the power supply.
I would love to resolve this, but I think it's going to end up being the motherboard again. I'm open to any troubleshooting you all may suggest though.
If it is the motherboard, we would like to replace it as cheaply as possible. The ASUS PSN32-SLI Deluxe is discontinued, and so is the Intel Pentium 4 650 Prescott 3.4GHz LGA 775 84W Single-Core Processor. What motherboard (preferably ASUS) is out there that will run this processor, and how much will it cost? Also, what would be the cost of replacing the mobo and processor comparable to this?
Also, he is using the built in RAID array on the P5N32 to run RAID 5 so if we replace the motherboard we are going to need a standalone raid...
