First a summary of my setup, Asus X99 A-II mobo, i7 6900k CPU, Titan XP gpu, EKWB predator 360 water cooler, EVGA1000W ps.
Recently had a catastrophic WC failure. Hose disconnected from radiator and emptied onto bottom of case and floor.
After several hours my machine shut down. Once I discovered the error I removed power and water cooler. AFAIK no coolant splashed on mobo.
Just installed a replacement water cooler this evening and then hit the power button on the mobo to check if everything still works. All fans and LEDs were working. Then hit the same power switch on the mobo again to power down and unplugged power supply.
Then after plugging in a 2nd time and hitting the on off switch on my PS NOTHING!
I should be seeing flashing LEDs on my mobo.
Of course it would not boot!
Freaking out now and don't know what to do next.
Does this sound like possibly a short in my PS or mobo?
How can I test for this?
