Hello everyone,
I am quite new to overclocking and was hoping I was overlooking something with my new rig.
I have a DFI NFII Ultra Infinity with a IQHYA 2400-M chip. Everything is peachy until I try for over 2.4 Ghz (12*200). I cann't even get 202 FSB!!!!
Here are my specs and below that I listed what I have tried. Can some one please help? I was hoping to get atleast 2.5 Ghz.
Mobo: DFI NFII Ultra Infinity
CPU: AMD XP 2400-M (IQHYA Serial)
RAM: 512 MB OCZ Dual Channel DDR400, ultra low latency ram (2-3-3-6).
VIDEO: ATI 9700 Pro (Not Overclocked and set to 66 mhz).
HARD DRIVE: Dual 36 Gig Raptor in RAID 0
POWER SUPPLY: Antec TruePower 330 Watts
OTHER: I/O Magic DVD+-RW Drive
Cooling:
Antec SOHO File Server Case, w/ 2 rear fans, 1 blow hole fan, 1 side fan.
CPU Heatsink/Fan: Swiftech MCX 370, with 60 mm fan
Northbridge: Swiftech MCX 159-R, with 40 mm fan
Southbridge: Zalman ZM-NB47J Northbridge heatsink
RAM: Cooper Heat Spreaders
VIDEO: Vantec Iceberg Pro Heatsink fan
This is what I have tried and have right now:
Stable System:
12*200, with Vcore = 1.75; RAM 1:1 Ratio (50 C, using Sisoft Burnin).
At one point I had it running 12*205, with Vcore = 1.8, RAM 1:1, but the CPU got upto 58 C. But I can no longer get this to boot.
I couldn't up the FSB until I went down to 10*200-208 @ 1.75 Vcore. 209 caused windows to crash.
Tried and failed:
13 * 200, with Vcore = 1.8 - 2.0, Chipset = Auto, 1.6 - 1.9 (boot up would loop)
12*202, with Vcore = 1.775-2.0, Membory 1:1, no boot....long beep every 3 seconds.
11*202, with Vcore = 1.750-1.8, Mem 1:1, no boot...long beep every 3 seconds.
10*209, with vcore = 1.750, Mem 1:1 would boot, but windows would crash.
10*210, with vcore = 1.8, Memory @ 177 mhz (6:5 Ratio), no boot...long beep every 3 seconds.
SO....WHAT DO YOU GUYS THINK. WHAT SHOULD I TRY????
Thanks in advance!
Sax
Cooling:
Stable System:
Tried and failed:
Thanks in advance!
Sax
