Ok, it's time to explain how we're going to be doing the window mod. First, we will be drilling four holes like this:
Then, we will use a ruler to guide the pneumatic nibbler from one corner to the other, like this:
The result of this will be a nice looking hole for a window. The four holes we drilled will make perfect looking rounded edges, like this:
That's about it for cutting the case panel. Here are some pictures of us making the holes. Yes, my dad did all of the work. He's the best at it, and he prefers to be the one to use his tools.
Here is my dad with the paneumatic nibbler.
If you haven't figured it out yet, the nibbler will touch the ruler, so that it makes a perfect line. Here's my dad measuring the distance between the ruler and where the nibbler made its cut. We needed to know this so that the cut the nibbler made would meet up perfectly with the four holes.
Here's my dad figuring out where to drill the holes.
Drill press!
A new hole!
Metal bits!
Jagged edges!
Way better edges after using the tool in the picture. I don't know what it's called, but I can find out if anyone wants to know.
Ok, so I know maybe you had seen the teaser picture and were expecting something a bit more dramatic. The truth is, nothing bad happened. IndiMint was just really scared something MIGHT happen, but the drilling went fine. The case panel made a lot of racket while being drilled, but that's about it.
More pictures coming sooooooon! Maybe even a picture of the new aggressive fan guard! :O
Oh, and yes, I have a lot of the work done already, I'm just releasing the photos really slowly to tease you.
