- Oct 6, 2005
- Fayetteville N.C.
This is in the wrong section. This should be under extreme cooling
you FAIL!
you FAIL!
Have you tried alcohol as coolant? I hear Vodka has best heat transfer properties.
It beat Crysis easy. It's got a sharp pont that destroyed the CD so it can never be used. Not only did it win, it won hands down. Even the non-OC one won.
Now thats a pen, to beat all pens!!!!!
My pen is better than all your E-Pens, it beat Crysis without even getting to the Bios screen. It's uber fast.
My E-Pen beat Crysis before the Bios loaded, RULZEZ!!!
man, don't get such a big E-Peen over your E-Pen.
You need a 12v battery and jumper cables- see what it does with some extra volts
