- Feb 20, 2005
- netherlands
does anyone know the brand tagan ??
http://www.tagan.com/main.htm
Welcome to the forums x2
Decent quality, OEM made by Topower, however very poor customer service. For similar Topower units with better customer service, check out the OCZ Modstreams. Or even better, the Powerstreams. Other brands using Topower are Globalwin, BeQuiet, Aerocool, and A+GBP.
bencze said:Does this mean the above mentioned PSUs should be as good as like OCX? Like perhaps I cannot afford OCX but I can afford an 550w Aerocool.. ?
Another question, saw that the 12V is very important to look at when buying a PSU .. saw many - supposed to be good - PSUs with like 30A and more, that's nice I guess. But also seen many 2 x 12V ones with like 15 or 18A on each of the 12Vs, what's that? Is that okay or what? Saw that it's some ATX 2 or something but I really don't get it (curious bc I want to buy a new PSU and not sure if it's okay for me to get one of these or not).
bencze said:I just checked my Codegen - it is 300W, it's saying 16A on the 12V... anyway not sure it's true just wondering.
Voltages are:
3.3 - 3.15
5 - 5.08
12 - N/A (for some reason)
These according to MSI Core Center (latest bios and software).
Is that 3.15 V enough or not really? Just wondering.![]()
CunningLinguist said:Yeah, based on a lengthy discussion from another thread, I ended up choosing the Fortron Blue storm 500W model.
BrutalDrew said:Thermaltake PSU's tend to droop their rails under load. They are not recommended.
3DFlyer said:Please don't take this as a slam, but I have got to be honest here. ThermalTake PSU's just plain suck! They are unstable pieces of crap! I had one, and after numerous tries trying to OC a good DO stepping SL7KC Prescott I bought a OCZ PowerStream 520- end of issue, it clocked to 3.8GHz with no issue at all. Just yesterday I got up the nerve to try 4.0GHz. The system will run no problem at 4.0GHz and is stable as can be. The system did run a little hot during benches, but that is because I could use either some water, or a faster fan on my HSF (Zalman 7700).
There are many good power units, but the ThermalTake isn't one of them. It caused me nothing but problems. The 430 I had didn't have the amps needed for these high power systems. Like was stated, it drooped badly! You could actually hear the dam*ed fans drop in rpm when any kind of load at all was put on the system.
Please people, if you are going to overclock, do NOT mess with a ThermalTake power unit. It will cause you trouble. They are OK for a stock system depending on what proc is used, but this is not stock system forum- it is an OC Forum and people here have alot of money tied up in expensive equipment. It takes a good power unit to power these things. I learned the hard way.
