- May 31, 2004
Is a Q6600 G0 just a better heat spreader?
I observe that my Q6600 B3 has a temperature difference between surface and core of 20c, but my G0 is just 10c. I wonder if Intel has found a better way to conduct heat to the surface and/or made the surface flatter and that is the main reason for the higher surface heat specification? I wonder if lapping a B3 will nearly produce a G0? What temperature improvement happened after your lapping?
Here is one rather pointed comment I found on the net: "Indeed, I had to lap my rather hot but golden E6700 to acheive 3.8ghz @ 1.46v load only. Now with the G0 Quad 6600, I don't need to bother lapping the suppose expensive CPU and retain the 3 yr warranty. I do also notice my Q6600 G0 IHS is preety flat when I put it on a piece of glass and used the razor blade test. The IHS doesn't look like the common poorly concave/convex IHS."
Record your full load difference in temperature on your Q6600 using CoreTemp 0.94 and SpeedFan 4.32 for consistency. PECI must be enabled in the bios.
eg:
Stepping: G0 [Q6600 only]
Load diff: 47c - 37c = 10c (core minus surface temp in celcius = difference) [CoreTemp 0.94 & SpeedFan 4.32]
Heatsink: water Swiftech h20-220
Lapped: no
Stepping: B3
Load diff: 58c - 38c = 20c
Heatsink: water Swiftech h20-200
Lapped: yes, 2c drop in CoreTemp, 3c surface temp (SpeedFan)
eg:
Lapped: no
Stepping: B3
