- Dec 17, 2010
- Greenville, SC
Hey guys.
I was hoping someone here (read: electrician ) might be able to shed a little light (no pun intended) on 256-color LEDs and how they're controlled. (XClio's 256-color cases, for example.)
With no real knowledge of how they're wired, it's my understanding that the 4-pin LED is fed current both on each individual pin, resulting in red, green, and blue light, and on a combination of those pins, achieving a mix which results in the 253 colors in between, the fourth pin being ground. Right?
If this is correct, I'd like to know how XClio's little board causes the LED to cycle through the spectrum. My guess is that it's a rather simple formula that starts with power to the red pole (please forgive (and correct) improper terminology) and gradually increases the voltage to the green pole until the first two are at full brightness, producing a change from red to orange to yellow. Then the voltage to the red pole is ramped down, creating a change from yellow to green. Needless to say, rinse & repeat with green & blue then blue & red and the LED makes its trip around the color wheel.
I could be way off here, but I doubt it. So I guess what I'm really asking is this: How difficult is it to create a circuit board that can produce these formulaic changes in voltage with a continuous rheostat (or is it a potentiometer)? This is possible, isn't it? Am I at least on the right track?
