- Jul 12, 2007
SAPPHIRE Radeon HD 7970 OC VS SAPPHIRE Vapor-X Radeon HD 7970
I learned there some differences noted below but I don't know what they mean for me as a consumer and if the $50 difference in price is worth the noticeable difference in performance.
1. The vapor-X is a GHZ edition card, it's basically clocked higher and it's a binned processor. The Dual-X is a boost card and it's not a binned processor. Is binned processor better because it was a better processor but has some of its features disabled?
2. The vapor-X has better PCB component design than the dual-x. Does the dual-x's lack of quality pcb design and flimsy board cause the card to warp or bend over time due to the gravitational weight hanging from a vertical case, thus causing BSODS and crashes?
3. Which one has unlocked voltage?
4. The vapor-x has better overclockablility, cooling and PCB design than the dual-x. Benchmarks would show there is a noticeable difference. Do you think an extra $50 is worth the noticeable overclocking difference in playing games tho?
