Hi guys.I am going to build a pc.I want to buy an Asus maximus viii hero and I want to build a water cooling system with one radiator placed on the top of the case that put the air out.With this system I want to cool cpu and gpu.Now I want that all the fans in my system are controlled based on the higher temperature that is detected in the system.For example:if cpu temperature is the higher between all the other component''s temperatures i want that all fans will be adapted based on that temperature...The same if the gpu''s temperature is the higher or if the hard disk''s temperature is the higher.Is there a way to do that?Is this a good idea?
