- Oct 12, 2001
- Los Angeles
- Thread Starter
- #81
In the cage with them! Have 3 slots left which is kind of a problem being that I have 4 HD's in my machine.Deathknight said:Good stuff Nik I see you have your pumps mounted in the 3.5 inch drive cage. Where are you planning on mounting your drives?
No dual card yet Yes in series for sure. The green is not so neon in person... I swear!ShoNuff said:It looks like you are going to run those bad boys in series. Are you using a dual card config?
The more I see the green the more I like it. Good choice Nik.
nikhsub1 said:No dual card yet Yes in series for sure. The green is not so neon in person... I swear!
Thermochill. That one is the HE 120.3 but the one to get is the PA 120.3NODES said:Off topic - What is the name or brand of this rad?
http://www.anonforums.com/forums/showthread.php?t=95
nikhsub1 said:Thermochill. That one is the HE 120.3 but the one to get is the PA 120.3
phide said:Only two pumps? I imagine you'll be dissatisfied and add another at some point.
ThermoChill HE/PA120.3s are ~$120 US. ThermoChill's official distributor list doesn't actually list any Canadian retailers that stock them, but Jab-Tech (jab-tech.com) will ship to Canada. Jab-Tech says that it's unlikely you'll have to pay duties for airmail, but you'll likely pay duty for UPS shipments.
The extra cost of ThermoChill rads is something that typically only Mountain Mods case owners would probably justify, as they're the only 360mmx120mm that will fit in a U2-UFO without modification.
Care to elaborate on that? Yes externally it won't be subjected to inner case temps, but where inner case temps are the same as ambient... plus, if the rad is drawing air from OUTSIDE the case I don't see it making one bit of difference.NODES said:i usually mount my rads externally, alot better temps that way.
nikhsub1 said:Care to elaborate on that? Yes externally it won't be subjected to inner case temps, but where inner case temps are the same as ambient... plus, if the rad is drawing air from OUTSIDE the case I don't see it making one bit of difference.
With the dual DDC Case receives the power user the maximally possible performance. The already very good power ratings of the Laing DDC pump are doubled thereby nearly. For this two pumps are serially interconnected. By the increased pumping performance it is possible to improve the efficiency of the entire cooling system. Apart from the possibility of connecting two pumps dual DDC Case offers also G ¼ threads for the assembly of conventional connection systems. The housing consists of poured acrylic glass as well as a cover plate of high-grade steel.
Real-estate options? You mean the GIGANTIC cube case he has that will probably have no problems with having everything mounted inside of it?citronym said:Yea that top is nice and it would surely be convenient for some, but I think the way yours are mounted is the best way to go, considering the real-estate options at hand.
