- Mar 26, 2002
- San Francisco
I got my water up and I wanna know if I should be doing better or not. Here's what I got:
XP-1600 @ 1886 MHz w/ 1.8v
CPUFX Z4 revised CPU block
---in series with---
CPUFX GF3 block
All on a 3'8" bong. The waterhead is now particlizing the water pretty good (blocked off some holes). It falls about 12-18" before it hits the sides of the bong and coasts down to the bottom. When it hits the sides it covers the entire sides of bong, lots of surface area.
I currently have a ~35 CFM fan on there.
I run SETI so my temps are 32-33C when I'm not doing anything and 33-34C when I'm using the machine. My guess for the ~1C rise is that once I get on the machine the video card has do do something, when I'm off it the monitor shuts off and it's basically idle. My MSI 'chassis' temp is 36C - obviously wrong, but at least I'm under it.
I'm thinking of rheostating a Delta 92mm to get more air in there without blasting a mist out the top of the sucker.
Here's some bad pics, my digi-cam is a DV-cam, so it's made for video, not stills.
--Illah
CPUFX GF3 block
--Illah
