If it is version 28.xx 84 on blend is about you can expect. Try running Aida stress test instead and see where your temps are. Your cpu should be totally fine. If you're having trouble with your cooler then who knows maybe that is why it's getting so hot. I mean if where ever you got the cpu is willing to just give you another then i guess it won't hurt but it will throttle and shut down before any real damage will occur due to heat. With an air cooler you might be better off making sure it is an older version of p95 like 26.6 if you're going to stress with it. And usually the fft test is to test your thermals anyway. Blend is better for stability.
My Maximum temperature at 4.2GHz is 70c running Prime95 version 28.10 and I have the same Hyper 212 cooler. So you definitely have a problem, I would agree RMA the CPU heatsink fan.
When I did the test for temperature I was overclocked to 4.2GHz with stock default voltage. When folks overclock Intel it is the Turbo that is overclocked as far as design. All you need to do to overclock to 4.2GHz is just change the CPU multiplier.
The 6700k has a turbo of 4.2 out of the box. I hit a max of 81c on p95 28.10 at 4.5 Ghz 1.312v with an h100i. But earlier versions, Aida, Realbench etc. 71-72c max. And it's every so often that it hits the max temp, my average was mid 60's on all but the new p95, mid 70's on that. But ya stock with aida in the 80's, raises alarm. All you have to do for your cpu to run 4.2 at all times is change your Windows power plan to High Performance.
I don't have that option, that is overclocking from the motherboard Vendor.Go into bios right now load defaults power plan H.P.
I have overclocking presets like 4.2-4.6GHz.
Guys, on some boards, vendors are taking the liberty to take the max single core boost clock and applying it to all cores as default. This is not new... nor on every board either. Asus boards have a 'multi core enhancement' function that can disable that 'optimization'. Not sure on other boards...Windows bud. I'm not gonna lie to you Wingman. Windows power plan. Windows as far back as at least 7 has this. Balanced, Power Saver and High Performance are stock power plans. This is how I have my cpu running at 4.5 Ghz all the time.
I don't have that overclocking option to sync all cores. Looking forward to the update.
