- Dec 27, 2007
- UK
my 3850 arrived today, time to set it up, I'll post my results ASAP!
Yes, pencil modded.
I doubt it since the stock cooler lacks heat pipes and less overall surface area of the S1. It may be ignorance, but all signs point to the S1 beating it hands down.
So I was pumped to get my sapphire 3870. Put it in and installed the drivers. Fired up Day of Defeat: source. It will run at 70fps for 3 seconds then drop like a rock to 20fps then back up then down then up. Making it really hard to play. Considering my stock 7900gs didn't do that dip thing, the fact that it would do like 45fps but stay there helps out more. Any ideas?
7.12 drivers. XP64. The rest of the computer specs below.
I have the same Sapphire 3870 and I am fine in DoD:S. You may just need a fresh DoD:S install. I had the same issue with CSS a while back, a reinstall worked for me.
PS; add me to your steam friends, meta_abuse. I am always playing DoD:S
Nice to see another dod:s player around here. You have been added. Just a question though, what drivers are you using? Oh and how do you "reinstall" dods? Just delete the local content and download again?
ok. I just ran 3dmark06 and with my 3870 @ 845/1200 and my opteron at 2.6 I got about 9200. It seems like there is something really wrong with my setup and I might blame it on the xp64. Course it might be the 7.12's.
Any xp64 owners out there with input on which drivers to use?
edit: (9192 in '06 to be exact)
Update: volted up to 1.55 both cards.
