- Apr 16, 2009
- Prince George, B.C.
DAAAAAMMMMMMMMNNNNNNNNNNNNN MEDRED that is a sick case! big time props for that.
Beautiful setup MedRed.
Here's a WC setup I finished a few weeks ago.
Where is the rest of the raddage?
onefstsnake got it right. The third picture down is a bit too dark to see the RX240. It would be nice to think that the bottom right hose fed in to an extra dimension of infinite radiatorage and airflow.
Thank you MedRed and Evochuck
I'll create a topic for this later on... has anyone seen a heightening mod done to the top of a case to fit an extra 55mm thick radiator?
Thinking of shaping an aluminum box that can house another RX240 then mount it through a cutout on top.
Edit: Someone should ask what is supporting the GTX480... it's great.
m0r7if3r,
1.25V on GTX 480 maxes out at 57C after thirty minutes of Furmark.
1.4V on i7 940 maxes out at 70C after an hour and a half of LinX.
Besides the stress and stability test temps. Playing a game like Crysis or Dragon Age for a few hours will yeild a Max GPU of 51C and max CPU of 62C from realtemp.
m0r7if3r,
Thank you Anti_808.
It took two days of my free time to sleeve the cables, be prepared for numb fingers and slightly burnt carpet/fingers/arms.
Edit: MedRed, I can't stop thinking about adding some 'throttle body' intakes around your radiators/fans. It would be ready to take off.
Out of curiosity, what is your ambient and is the CPU temp with HT off?
+1...nice job MedRedBeautiful setup MedRed. [/IMG]
So I cut a cheap plastic ball-point pen with a razor and stuck it inside a cut piece of old 3/4"OD tygon tubing to prop it up.
Yours is pretty sweet too TaHoward
