- Sep 3, 2010
Hello!, i recently purchased a Q8300 quad. Im having problems overclocking it, i have searched the web and found out that this CPU isnt an amazing overclocker (-_- that isnt what the website i brought it off said! ), anyway, i ramp up my FSB to 400, with 1:1 RAM ratio, i have my RAM set to 2.1V which is normal. My VCORE is at 1.34V atm, its normal is 1.28V if my memory is correct, while my FSB Voltage is normal (Didnt want to change because i have no idea what it is, so this may be the problem!)
It boots fine with these settings, logs into windows fine etc etc. I load up Prime95 and get an error after the first test, and when i listen to my CPU it makes a weird noise, im not sure if this is normal or not, but my old Pentium D did it when i overclocked it a bit, but i can't recall my E5300 doing it atall.. even at 3.8Ghz from 2.6. i am worried about that as i dont want it to just explode and have my £120 down the drain. Anyway Prime95 gets an error so i stop it, my CPU temps are only 62c max at 100% load with Prime95 so i dont believe it is my temps (I use Everest Ultimate to monitor temps) and idles around 32c. I dont want to push my VCORE too high without any advice from you guys, right now im leaving it stock settings until i can get any advice
Thanks for reading!
Here are my specs incase you need it:
Gigabyte GA-G31M-ES2L
4GB OCZ OCZ2F8002G DDR-6400. (5-4-4-18)
500GB Samsung HDD
300GB Seagate HDD
ATI Radeon HD 5670
And a DVD Rewrite
Thanks for reading!
500GB Samsung HDD
300GB Seagate HDD
ATI Radeon HD 5670
And a DVD Rewrite
