I want to try and upgrade an older computer from an AMD Athlon 1 ghz chip to a 1.4 ghz on a AK37GT MOBO which supports a (according to the manual)..
.. AMD Athlon Proc w/200/2660 Mhz FSB
.. AMD Duron Proc w/ 200/266 Mhz FSB
.. AMD Athlon XP Processor w/ 266 Mhz FSB
(chipset features VIA KT400, BT8667 N.B. and VT8233A S.B. - for more details see below)
However, I read that a chip greater than 1.4 Ghz can be used. I'm curious... does anyone knows what precisely are these limitations to exceed the 1.4 Ghz limit with particulars to the Shuttle AK37 MOBO
I've done a search and am not able to find particulars. However, it seems that other forums indicate that certained AMD Socket462 chipsets can be used (and, have been used) successfully. However, they must be an "unlocked" version dated after a certain model (i.e. 340 or greater).
I have found very little information regarding my particular MOBO (i.e., the
Shuttle AK37GT) limitations regarding the ability to use a AMD chip beyond
the text book/manual 1.4 Ghz Athlon chip limit.
Anyone with particular experience with this older model MOBO and have used a chip faster than 1.4 Ghz (BTW, the MOBO currently runs a 1 Ghz AMD Athlon Chip?
Joe
Details and MUCH More information regarding my system...
Field Value
Motherboard Properties
Motherboard ID 08/09/2004-AK37-6A6LYH29C-00
Motherboard Name Shuttle AK37GT(R)
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 100 MHz (DDR)
Effective Clock 200 MHz
Bandwidth 1600 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 5:3
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
Bandwidth [ TRIAL VERSION ] MB/s
Chipset Bus Properties
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 67 MHz (ODR)
Effective Clock 533 MHz
Bandwidth 533 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 Socket 462
Expansion Slots [ TRIAL VERSION ]
RAM Slots 4 DDR DIMM
Integrated Devices Audio
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset KT400
Extra Features [ TRIAL VERSION ]
Motherboard Manufacturer
Company Name Shuttle Inc.
Product Information http://global.shuttle.com/Product/M..ad/Download.asp
Field Value
North Bridge Properties
North Bridge VIA VT8377 Apollo KT400
Supported FSB Speeds FSB200, FSB266, FSB333
Supported Memory Types DDR-200 SDRAM, DDR-266 SDRAM, DDR-333 SDRAM
Revision 00
Package Type 664 Pin HSBGA
Package Size 3.5 cm x 3.5 cm
Process Technology 0.22 um
Core Voltage 2.5 V
In-Order Queue Depth 4
Memory Controller
Bank Interleave 4-way
Memory Timings
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 7T
Command Rate (CR) 1T
Memory Slots
DRAM Slot #1 256 MB (PC2700 DDR SDRAM)
DRAM Slot #2 256 MB (PC2700 DDR SDRAM)
DRAM Slot #3 512 MB (PC2700 DDR SDRAM)
AGP Controller
AGP Version 2.00
AGP Status Enabled
AGP Device ATI Radeon 7000/Radeon VE DDR
AGP Aperture Size 128 MB
Supported AGP Speeds 1x, 2x, 4x, 8x
Current AGP Speed 4x
Fast-Write Not Supported
Side Band Addressing Supported, Enabled
Chipset Manufacturer
Company Name VIA Technologies, Inc.
Product Information http://www.via.com.tw/en/products/chipsets
Driver Download http://www.viaarena.com/?PageID=2
Driver Update http://driveragent.com?ref=59
Problems & Suggestions
Problem Current AGP speed is lower than maximum supported. This may cause performanc
e penalty.
Field Value
CPU Properties
CPU Type AMD Athlon, 1000 MHz (10 x 100)
CPU Alias Thunderbird
CPU Stepping A9
Instruction Set x86, MMX, 3DNow!
L1 Code Cache 64 KB
L1 Data Cache [ TRIAL VERSION ]
L2 Cache 256 KB (On-Die, Full-Speed)
CPU Physical Info
Package Type 453 Pin PGA / 242 Contact Slot A Cartridge
Package Size 4.95 cm x 4.95 cm / 13.99 cm x 6.27 cm x 1.64 cm
Transistors [ TRIAL VERSION ] million
Process Technology 6Mi, 0.18 um, CMOS
Die Size [ TRIAL VERSION ] mm2
Core Voltage 1.75 V
I/O Voltage 1.6 V
Typical Power 34 - 65 W (depending on clock speed)
Maximum Power 38 - 72 W (depending on clock speed)
CPU Manufacturer
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us-en/Processors.. />
18,00.html
CPU Utilization
CPU #1 1 %
Field Value
Memory Module Properties
Module Name Kingston K
Serial Number 011E6652h (1382424065)
Manufacture Date Week 37 / 2003
Module Size 256 MB (1 rank, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC2700 (166 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
@ 133 MHz 2.0-3-3-6 (CL-RCD-RP-RAS)
Memory Module Features
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Memory Module Manufacturer
Company Name Kingston Technology Company, Inc.
Product Information http://www.kingston.com/products/default.asp
Field Value
Module Name [ TRIAL VERSION ]
Serial Number 4818D3A7h (2815629384)
Manufacture Date Week 49 / 2003
Module Type [ TRIAL VERSION ]
Module Width 64 bit
Memory Timings
Field Value
Serial Number None
Module Size 512 MB (2 ranks, 4 banks)
Module Width 64 bit
Memory Timings
Field Value
CPUID Properties
CPUID Manufacturer AuthenticAMD
CPUID CPU Name AMD Athlon(tm) processor
CPUID Revision 00000644h
Extended CPUID Revision 00000744h
Platform ID CFh (Socket A)
IA CPU Serial Number Unknown
HTT / CMP Units 0 / 0
Instruction Set
64-bit x86 Extension (AMD64, EM64T) Not Supported
AMD 3DNow! Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Supported
AMD Extended MMX Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Not Supported
IA SSE 2 Not Supported
IA SSE 3 Not Supported
IA SSE 4 Not Supported
VIA Alternate Instruction Set Not Supported
CLFLUSH Instruction Not Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
MONITOR / MWAIT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features
Automatic Clock Control Not Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Not Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Not Supported
Thermal Monitor 2 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Not Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Not Supported
L1 Context ID Not Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Not Supported
Physical Address Extension (PAE) Supported
Secure Mode Extensions (SMX) Not Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Not Supported
Time Stamp Counter (TSC) Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
Suggestion SSE is not supported. Upgrade your CPU to speed up applications o
ptimized for SSE.
Thanks Joe
Joe
Field Value
Bus Width 64-bit
Bandwidth 1600 MB/s
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 5:3
Bus Type VIA V-Link
Bus Width 8-bit
Bandwidth 533 MB/s
Form Factor ATX
Field Value
Revision 00
Core Voltage 2.5 V
Memory Controller
Memory Timings
Memory Slots
AGP Controller
AGP Version 2.00
AGP Status Enabled
e penalty.
Field Value
CPU Properties
CPU Stepping A9
L1 Code Cache 64 KB
CPU Physical Info
Core Voltage 1.75 V
I/O Voltage 1.6 V
CPU Manufacturer
18,00.html
CPU Utilization
CPU #1 1 %
Field Value
Module Width 64 bit
Memory Timings
Field Value
Module Width 64 bit
Memory Timings
Field Value
Serial Number None
Module Width 64 bit
Memory Timings
Field Value
CPUID Properties
Instruction Set
IA-64 Not Supported
IA MMX Supported
Security Features
CPUID Features
ptimized for SSE.
Thanks Joe
