- Nov 22, 2018
- Nebraska USA
I agree, you cannot ignore them. Verifying the PSU is outputting proper voltages is critical. But as noted, you need to verify the motherboard's divider/regulator circuits are working too. HOWEVER, the fact your CPU, RAM, and graphics processors are working sure suggests those voltage are "probably" correct. That said, because the system (typically the chipset) temp is way off too, I agree it would be good to check them too if re-flashing the BIOS firmware does not clear this.
So how do you verify temps? That's not too easy. What I recommend you get a decent laser guided IR thermometer gun. Because you can't get past heatsinks or zap through fans, you will not be able to confirm actual temps. But you can come close. If possible, point the laser at the base of the heatsink, on memory chips on your RAM sticks and (if possible, graphic card).
How do you verify motherboard voltages? That's a greater challenge without a schematic showing test points or expected voltages. Checking voltages on motherboard fan headers will show your +12V. And there should +5 on the USB connectors as seen here.
I personally don't believe you are facing immediate risk of motherboard failure so there is not an immediate need to upgrade. But if re-flashing does not clear this, then I sure would recommend you start building your budget and start looking to replace it sooner rather than later.
And by all means, you should immediately back up any data you don't want to lose - just in case.
