Wow awesome! I allready seen your work on 9700/9800s. Impressive how professional you do your work.
A question for ViperJohn: (and anyone else who knows a lot about modding ATI cards)
Since i am a poor student i can't afford to let you mod my card. I got a powercolor x800 PRO VIVO. Flashed to 16 pipes. I can run 510/575 in 3dmark and Doom 3 but if i play Joint Ops i get green artifacts on textures with memory above 520!
I think it's a heat issue. People say GDDR3 is cool but the chips get very hot in reality.
I did a pencil vmod to 1.48 and could get the core higher but it went to 85 degrees load wich is too much so i undid the mod.
I plan to buy the arctic cooling VGA silencer 4 wich is cooling the memory as well. People get temp drops of nearly 20 degrees with that cooler i read.
I know it's not as good as your solution but it's easy to mount and cheap.
The card should load around 60-65 max with that cooler applied. What voltage could i go for? 1.45, 1.48 or even 1.5? I only plan to get it stable on XT PE clocks so i can flash in the XT PE bios and don't need to adjust clocks via software anymore. 1.45 should be no problem if i am at 65 degrees right?
Here's a pic of the texture error i get in Joint Ops. Strange that i have no trouble in 3dmark 03 at much higher clocks isn't it? Do you think memory cooling and a vcore increase could help to bump my (1.6ns) memory to 560 mhz?
Edit: On Ruby double Cross demo i can run at 500/500 max or i get artifacts in her hair. I can do 520 on core (with a slight vmod to 1.42) but in combination with high memory speed i get artifacts. 485/575 shows no artifacts though so i guess i just need a bit more volts on the GPU.
Didn't try it with higher vcore yet since it got too hot for my liking hen i tried. (Forgot to test ruby then)
