I guess I don't know what you mean by focus on the basics. I've already done quite a bit of reading and read through some beginners guides. I'm not done reading by any means, but I think I'm ready for a more advanced guide. I'll just highlight what I know in each area so you can see where I'm at knowledge wise and I'm sure how far I have to go. But I do want to learn, so just as I did when I started building computers I'm going to cover my bases on all component areas and make sure I make informed and educated decisions. I'm ultimately trying to become very knowledgable with computers. I've gotten the hardware side and building down pat. Now the next step is to advance into water cooling.
As far as general understanding about water cooling, I grew up on a farm and around mechanics. I understand the concepts behind water cooling. I understand about resistance through length of tubing and higher restriction blocks and pressure drop as all that occurs. I also understand that you're measuring your systems performance by the temperature difference of the water and your ambient air temperature. I get that the pump must always follow your resevoir so it's never dry and that order doesn't matter after that because it's essentially an entire body of water that is heated to roughly the same temperature no matter where in the loop you measure.
Radiators:
I know about the difference sizes (120.1, .2, .3, .4, 140.1, .2, .3, 200.1, etc). I've read that you should use a 120.1 for each block you're cooling except you want a 120.2 for an i7 due to them running hotter. I also understand about the fins per inch. HWlabs makes high fins per inch which are high performance radiators but only at high fan speeds to push through all the fins. Then there are radiators like the SR1 series that are optimized for fans with very low flow.
I personally would like to be somewhere in the mid range. I recognize that there's no way I'm going to be able to fit enough radiators inside an HAF X to cool an i7 920 and GTX 570 SLI all overclocked "silently". At the same time, I don't want a bunch of Scythe fans running at 2500 rpm and 50 dB either. I had stated the XSPC radiators above because in skinnee's review they were the best at mid range. I'd like to have fans I can run between 800-2000 rpm (or somewhere in that range) with a fan contoller. I don't mind turning them up some if I'm in hardcore game mode, but I don't want fans spinning at 2000 rpm all day long because that's louder than what I have now.
Pumps:
I haven't read as much about pumps because mostly everything I see uses a Swiftech MCP655. This pump seems to be a large pump than can pump through long loops with multiple blocks. I know that it's important to be able to maintain something like 2 GPM through your loop.
Hoses:
I know you do not want to buy cheap hoses. Cheap hoses will kink in tight places and I know I'm going to have tight places. I've read tygon is the best, although some of you guys are telling me Primochill LRT is all I need. I'm leaning towards half inch because it doesn't sound like there is much difference if any between half inch and 3/8, but the MCP 655 pump has standard half inch barbs and I can get half inch fittings for other blocks. I don't want a lot of reducers or adapters because that's just going to increas my chances of having a leak. I kind of wanted red colored hoses to match the red/black theme of the HAF X, but it sounds like they show up orange under UV light. I don't want mismatches on colors. I'll probably buy a black Primochill hose with red anti kink coils. Putting dyes in my system is completely out of the question as I do not want buildup in my system and would like to keep it as low maintenance as possible
Liquid:
Im planning on going straight distilled water from the grocery store. Right now I'm leaning on putting a silver kill coil in the line, but I could go with biocide too. Like I said, absolutely no dyes or additives other than a biocide.
Resevoir:
It doesn't sound like resevoir matters a whole lot as long as it comes before the pump. I want a bay resevoir with preferrably a black red theme. I was preliminarily thinking a Danger Den or XSPC 5.25" bay res that will feed down to my pump. But again, if I understand correctly resevoirs are mainly chosen by location/aesthetics as long as it's before the pump. I do understand that a res is responsible for getting the air out of your system, but I assume any decently branded res will be able to do that?
Fittings:
I know there are 3 types of fittings: barbed, compression, and quick diconnects.
I will say that I don't think I really want barbs just because I'd like to have the clean look of compression fittings. I haven't done as much research on fittings yet, but I know I'm going to want at least one QDC to drain my loop. I've pondered a t-line with a QDC I can attach to drain the loop or also putting my graphics cards on QDC so I can remove them if I need to and also I can then just hook up a spare hose and let the loop drain. If I were to do barbs they would be metal and not plastic.
Fans:
Well there's a million of them. I don't think I'll have room in my case for real thick ones (32mm, I'd probably opt for 25mm). I also want one that can be adjusted between 800-2000 rpm with a fan controller. I'm planning on having one fan per 120/140mm slot. I haven't decided on the push/pull/air flow of the case yet. That will all depend on radiator sizes/locations etc.
Waterblocks:
It sounds like the Apogee XT and EK Supreme HF are the two flagship blocks. I know the EK is a high flow and the Apogee is a more restrictive/low flow solution. I've read that the revision 2 of the Apogee is much less restrictive though. I haven't read literature directly comparing the two yet, but I'm guessing with me trying to fit in one loop I'd be best to go with the lower restriction solution.
As far as GPU I'm going to go with a full coverage solution. I'd be all about the EVGA HydroCopper block if they made one with a GTX 570 sticker on it, but since my block is going to say GTX 580 anyways I'm probably going to go with the EK full coverage solution.
I know there are some metals you do not want to mix, but haven't spent enough time researching that just quite yet.
That pretty much sums up most of what I've read so far. That's not all inclusive, but I think most of what I'm missing out on are the details. If there is more conceptual research I still need to do I will, but I feel like I've read through basic beginners guides and have a pretty good guage of that stuff.
Thought's on anywhere I'm misled or things I need to understand better? I'm going to read more on heat output of my specific components and just keep scouring the forums.
