Well I'll just kind of explain to you my line of thinking in selecting QDC locations. Obviously, the graphics cards I want to have QDC on for a couple reasons. That will be the one part that is most likely to change. For example, I'll be building this with one card and adding a second one probably by the end of the year. Also, the intake of my graphics card block should be the lowest point in my loop, so I can disconnect from that and drain from there.
I also know I want to be able to remove my rear radiator with a QDC because when I transport my machine I don't want to take a chance of the radiator getting yanked off or the mounting bracket bent etc.
At this point I know I'm buying 4 male QDC's and 4 female QDC's. I had originally planned on putting them on the graphics and external rad. Then after some thinking and looking at the diagram I thought if I use the QDC's on the CPU block that will allow me to disconnect the external rad by disconnecting graphics out and cpu in. Then I can just pull the hoses and QDC couples through the gromets on the back of the case and I'll have my rad with a foot or so of tubing connected, but it will be an isolated system.
So, placing my QDC's on my CPU will still allow me to easily detach the rear radiator, still gives me the flexibility of changing graphics cards/draining my loop there, but also adds the flexibility to disconnect cpu and gpu should I ever need to pull my motherboard out in tact (such as upgrading to ivy bridge or the gen after that in a couple years).
That was my line of thinking anyways. I figure I'm buying 4 male and 4 female regardless. Doing it that way would give me the most flexibility. I'll have to pay attention to length and see if that causes many problems. If I'm buying 4 of each either way I can play around and see where they best fit.
