multichrome
- Nov 15, 2012
Any recommendations? I have no idea whatsoever about which one to get.
I'm looking to pair it with the
CPU: AMD FX-8120 Zambezi 3.1GHz Socket AM3+ 125W Eight-Core
(http://www.newegg.com/Product/Product.aspx?Item=N82E16819103961)
HDD: Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
(http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697)
MOBO: GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514)
GPU: EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625)
RAM: G.SKILL Ripjaws X Series 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
(http://www.newegg.com/Product/Product.aspx?Item=N82E16820231491)
So far it's totaling to just under $600, I'd prefer to keep it under $750. And any cooling system suggestions to go along with it? It's a gaming rig, so I', guessing it will heat up quite fast.
Any help would be appreciated, thanks!
