Hi,
I have a Gigabyte Gaming GT 980 ti and looking to add a second GTX 980 TI for SLI. I have a Acer 32' 4k monitor that I'm ruining at 75mhz. I'm looking at getting a EGA GeForce GTX 809 Ti FTW or a EVGA Gefore GTX 980 Ti Classified. I can't figure out what the difference between the two. They both run at the same speed. The only difference I see is that he Classified version requries 300 watts and uses 2x 8 pin ports and the FTW version that requires 275 watts and requres 1x 8 pin and 1x 6 pin. I do not plan on manually overclocking over the stock modes. There's about a $40 difference between the two. If anyone could provide me with a suggestion about which one I should get it will be very helpful. Thank you!
Classified
+http://www.newegg.com/Product/Product.aspx?Item=N82E16814487146
FTW
http://www.newegg.co...7-160-_-Product
David
PS. I decided not get another Gigabyte because it's kind of noisy. I read a lot of reviews that make a note about how quiet the EVGA cards are.
Classified
FTW
David
