What type of PS should i get for this set up???
-=sC(+)Pe=-
T-Bird 1.2 @ 1.4 (156w TEC)
Asus A7M266
512MB PC2100 DDR
GeForce II GTS Pro 64MB DDR (80w TEC)
4x20GB HDs running RAID 0 (constant spin of all 4 drives)
Promise Raid Controller Card
SB Live 5.1
DVD + CD-RW
DVD Controller Card
3Com 10/100 NIC
Now the Question... will a 430W PS Handle this?
Hoot
Inactive Moderator
Twin Cities
The 430W supply is an excellent choice for your setup, but don't even think about running the Peltier off of you PC PSU. You can get a 12V 22A switching supply for $40.00. It will fit inside or outside your PC and is more than adequate for that 156W pelt.
Hoot
Fink
Ditto with Hoot, I suggest Enermax powersupplies - quiet and stable voltages.
jordan
if you are going to do it, do it right- you will need two psu, you can get two 450W enermax for $99.00 each
Tachyon
Senior Member
Arkansas
-=sC(+)Pe=- (Mar 27, 2001 11:52 a.m.):
Asus A7M266
512MB PC2100 DDR
SB Live 5.1
DVD + CD-RW
DVD Controller Card
3Com 10/100 NIC
Could you please remove the link from your sig line until you recieve permission.
Sketch
Tulsa, OK
Listen to Hoot!! That would be a great solution. If i were to give a psu opinion i would tell you to go with Enermax Psu's.
