- Jul 30, 2002
- Midland, Ontario
I do supose you are correct, computers are so fast now, people don't care if the software is bloated, Hence VB, and now I guess Java, being Popular
Cowboy Shane said:
I work in the real world, and I work at a Delphi shop. That means that nearly everything I write at work is written in Object Pascal. Of course, we are planning migration strategies for c# should .net trully replace win32 as the preferred programming environment for Windows, but Pascal is definately not just a toy language.
Cowboy Shane said:Delphi is a rapid application development environment similar to Visual Basic, but it uses Pascal for its language. It's closer to Borland's C++ builder than it is to VB, but you get the idea.
Borland's compiler and development tools make it so easy to program it's more like a game than programming.
Roof Jumper said:the problem is, VB.NET is slow as crud, JAVA still cant do trig mathematics worth a darn. Also, JAVA may be portable, but it is still almost as slow as VB.
