- Oct 23, 2002
- Muscle Shoals, AL
We've all had a week to play with the release candidate, so I thought it might be a good idea to have a thread consolidating some of the quirks and their fixes to make life a little simpler. So far my experience has been pretty positive, just a few hiccups here and there. I've been working with the x64 RC.
1. Creative X-Fi drivers. The beta drivers on Creative's website were horrible. Simple fix can be found here. It's Vista drivers modified to recognize Windows 7 as a valid OS. Still no volume panel, but I've read that if you install it off the OEM CD after installing the driver pack it will work. I'm downloading it now (since Creative released the Vista CD via torrent it's coming in pretty slow). Great support Creative.
2. X1900 series drivers. According to ATI's site 9.3 was suppose to be the last version to support the x1900 series. They're completely missing from the drivers. (x800 series is there). Solution. Use 9.2 series catalyst instead.
3. Print drivers (Canon S600). I had this install on a networked machine.
5. Not a specific problem, but several programs will generate a "this may not have installed properly" message. Double check before allowing any kind of reinstall because every program that has done this has run fine for me.
6. Win 7 (and Vista) will create a thumbs.db file in network folders where the you have write permission.
Otherwise I think we've got a winner here. It runs about the same as XP did for me (boot times, app load times, etc.). If anyone else has had any other quirks or major problems with solutions, feel free to post. Hopefully we can build up a decent knowledge base since I have a feeling a lot of us will be using this OS until next March at least.
a. First I tried to just add the printer, no driver could be found.
b. Then I rand Canon's driver add-on that adds Vista/Vista 64 support on the networked computer. Tried to use the "install additional drivers" on the hosting PC and none could be found.
c. Ran the installer update on the Win7 machine. Tried to connect to the printer, again, no drivers could be found.
d. I was about to give up, but on a whim decided to install the printer on the Win7 machine directly.
e. Printer installed to my surprise as "Canon Inkjet S600". All of Canon's drivers identify the printer simply as a "Canon S600".
f. After finding the ".inf" file, "oem11.inf", and removing "Inkjet" from the description, printer installed correctly.
g. The opposite also works. Adding "Inkjet" to the existing ".inf" files will allow additional drivers to be installed and network sharing with an XP/Vista 32 machine.
4. Coming from XP I was a little annoyed with the Start Menu. this Vista tweak also works with Win7. You can also use the Documents menu instead of favorites (which I recommend since it will mess up your IE favorites). Not really sure why that wasn't included as an option to begin with without reverting to a desktop that looks like Win95. If anyone knows a more elegant solution, I'd love to hear it.b. Then I rand Canon's driver add-on that adds Vista/Vista 64 support on the networked computer. Tried to use the "install additional drivers" on the hosting PC and none could be found.
a. In Windows explorer "tools->folder options->view" or "Control Panel->folder options->view" check the box "always show icons, never thumbnails". This will disable thumbnails everywhere though.
b. Registry fix. Under HKEY_CURRENT_USER->Software->Microsoft->Windows->CurrentVersion->Policies->Explorer add a new DWORD(32 bit) named "DisableThumbnailsOnNetworkFolders" without the quotes and set its value to 1.
