Table of Contents
Today, Lian Li announced the Q58 SFF chassis, a 14.5-liter mITX case with excellent versatility. It has the capability to house a triple-slot GPU up to 320 mm long and a 240 mm or 280 mm AIO cooler. Users are not limited to SFX power supplies either as the Q58 supports both SFX or ATX PSUs. Currently available at Newegg in black for $129.99 or white for $139.99. Below is Lian Li’s press release with the full specifications.
LIAN LI Launches Stylish and Versatile SFF Case Q58
September 17th, 2021, Taipei, Taiwan – LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, announces a new addition to its small form factor line up with the Q58, a compact case with enormous versatility. Available in black or white, the Q58 features split side panels made of mesh and tempered glass which can be interchanged to the user’s look and cooling preference. At only 14.5 liters, the Q58 is compatible with an impressive list of hardware, with support for SFX and ATX power supplies, up to 280 radiators, 320mm long and triple slot thick graphics cards, and still enough room for 4 SSDs.
- Compact 14.5L ITX case capable of supporting up to 280mm radiator
- Swappable mesh and glass side top/bottom split panels
- Fits triple-slot GPUs up to 320mm long
- Support for both SFX and ATX power supplies
14.5L ITX Case with Enormous Versatility
The Q58 comes equipped with the necessary mounting brackets for both SFX and ATX power supplies, providing versatile cooling compatibility for powerful components. In both SFX and ATX mode, the Q58 supports Mini-ITX motherboards and large triple-slot GPUs of 320mm in length. In SFX mode, the Q58 can support up to two 120/140mm fans or 240/280 radiator at the top and a 120mm fan at the bottom. In ATX mode, the Q58’s cooling compatibility is reduced to one 120/140 fan/radiator at the top and a 120mm fan at the bottom. All fan power and LED cables can be connected with a 5v addressable RGB and PWM hub located at the rear of the case.
To alleviate the lack of onboard storage of Mini-ITX motherboards, the Q58 can support up to four SSDs, or three SSDs and one HDD. The first mount is a toolless and hot-swappable SD card style bay at the front of the case. While one SSD can be mounted behind the motherboard tray in SFX PSU mode, and another one at the bottom of the case in place of the 120mm fan in both SFX and ATX PSU mode, the top of the case fan/radiator bracket can also be fitted with a storage expansion bracket to hold either a 2.5” SSD or a 3.5” HDD.
Stylish Yet Functional
The black Q58 sports a unique look with a dual-tone finish aluminum front panel, while the white version features a minimalist all-white front panel, a white silkscreen on the glass panels, and silver thumb screws to offer a harmonious look. Both the right and left sides of the Q58 are split with a bottom fine mesh panel and dark tinted tempered glass panel (black version only, the tempered glass panel on the white version is clear). All four panels are removable for easy access to the inside of the case and interchangeable to change the look and performance of the case. Users can decide whether they want an all-mesh side for better airflow or all glass to better display the hardware.
Additional Accessories
A dual-LED strip kit, available in black, white, and sold separately as an additional accessory, can be attached to the top and bottom of the right and left side panels to complement the look of the case. In addition, users can decide to change their Q58 tempered glass side panels to mesh with the Q58 Mesh Kit, available in black and white.
PRICING
US MSRP
Global MSRP
Black Q58 with PCIe 3.0
$129.99
$119.99
White Q58 with PCIe 3.0
$139.99
$129.99
Black Q58 with PCIe 4.0
$159.99
$149.99
White Q58 with PCIe 4.0
$169.99
$159.99
ACCESSORIES
ARGB LED STRIP KIT
$15.99
$15.99
MESH KIT
$15.99
$15.99
The Q58 is available for pre-order starting September 17. For more information about the Q58, please visit the product page: https://lian-li.com/product/Q58/
SPECIFICATIONS
DIMENSION
(D)342mm x (W)170mm x (H)250mm
COLOR
Black / White
MOTHERBOARD
Mini-ITX
PSU
SFX / SFX-L / ATX (Max. length 160mm)
MATERIAL
Aluminum Exterior
SPCC Steel Interior
3.0mm Black Tempered Glass
FAN
SFX PSU Mode:
(Top) 2x 120mm / 2x 140mm
(Bottom) 1x 120mm
ATX PSU Mode:
(Top) 1x 120mm / 1x 140mm
(Bottom) 1x 120mm
RADIATOR
SFX PSU Mode:
(Top) 1x 240 / 1x 280 (Max. length of 315 mm, or 325mm is front SSD tray is removed)
(Bottom) 1x 120
ATX PSU Mode:
(Top) 1x 120
(Bottom) 1x 120
GPU LENGTH
320mm
CPU CLEARANCE
67mm
STORAGE
SFX PSU Mode:
4x 2.5” SSD or 3x 2.5” SSD and 1x 3.5” HDD
ATX PSU Mode:
2x 2.5” SSD
EXPANSION SLOTS
3
I/O PORTS
1x USB 3.0, 1x USB 3.1 Type-C, 1x HD Audio
DUST FILTER
(Bottom) 2x magnetic
The Q58 is available at NEWEGG: https://www.newegg.com/p/2AM-000Z-00082
The Q58 is available at Caseking: www.caseking.de/lian-li-Q58
The Q58 is available at Overclockers UK: https://www.overclockers.co.uk/lian-li-Q58
About LIAN LI
LIAN LI Industrial Co. Ltd is one of the world’s leading consumer brands for PC chassis. With over 20 years of experience in designing and manufacturing PC chassis under its own name and community projects, the company has produced some of the most iconic designs to date. LIAN LI’s award-winning products are sold worldwide to PC enthusiasts, builders, and gamers. To learn more about LIAN LI, please visit http://www.lian-li.com/. You can also visit LIAN LI on Facebook, Instagram, and YouTube.
Loading new replies...
1
1
