Montech Launches AIR 903 BASE AIR 903 MAX E-ATX Mid-Tower Case
Montech just launched the AIR 903 BASE and AIR 903 MAX mid-tower chassis. With a focus on airflow, the AIR 903 BASE features three pre-installed 140 mm PWM fans. The MAX comes with four, three addressable RGB at the front and a non-ARGB at the rear. These mid-tower chassis are capable of housing large E-ATX motherboards and “any flagship RTX 4090 GPU”. Pricing starts at just $65 for BASE model in black. With the most expensive model, the white MAX, at only $79, these are priced to be within anyone’s budget.
MONTECH Launches the Ultimate Cooling Beast – AIR 903 MAX and AIR 903 BASE
Ultra-cooling Mid Tower with Max Capacity
Montech AIR 903 MAX & BASE
  • 51% Porosity Ventilation Rate
  • Fine Mesh Front Panel
  • AIR 903 MAX – Pre-installed HP140 Fans (3 x 140mm ARGB PWM + 1 x 140mm PWM)
  • AIR 903 BASE – Pre-installed HP140 Fans (3 x 140mm PWM)
  • 21 Built-in RGB Lighting Modes
  • Supports Motherboards E-ATX to SSI-EEB
  • Supports 360mm AIO Coolers/ 180mm CPU Tower Coolers
  • Clearance for large GPUs (400mm x 190mm)
  • Compatible with any flagship 4090 GPUs
  • Max Drive Bays: 2 x HDD + 4SSD/ 1 x HDD + 5 x SDD
  • Vertical GPU Mounting Supported with Additional Accessory
​Taipei, Taiwan – MONTECH, an innovative PC components and peripherals brand, announces the launch of its newest addition to the AIR PC Case series – AIR 903. Manufactured with premium grade materials and innovative design; the AIR 903 offers users a wide range of build options along with enhanced cooling performance. The AIR 903 is available in AIR 903 MAX and AIR 903 BASE, available in both black and white.
High-Performance Airflow
In order to provide users with maximum airflow for high-performance use, the AIR 903 series features an ultra-cooling front panel offering 51% porosity ventilation rate. Dust filters are also equipped at the top and bottom of the case for all-around dust protection.
Pre-Installed 4x140mm PWM Fans
AIR 903 BASE is equipped with 3 pre-installed HP140 high-performance cooling fans with PWM functions. On the other hand, AIR 903 MAX, is equipped with 4 pre-installed HP140, 3 of which are mounted at the front and features ARGB, and a single HP140 PWM at the rear. The pre-installed fans are connected to MONTECH’s LED/PWM controller – allowing users to easily switch between 21 RGB modes with the LED button. (Please note: controller only available for AIR 903 MAX)
Both cases can support up to a total of up to 9 x 120mm fans, or 6 x 140mm and 2 x 120mm cooling fans offering users the ultimate cooling experience. The fan RPM for both cases can be manually adjusted through BIOS.
Hardware Compatibility
AIR 903 is designed and engineered for maximum capacity, compatible for both air cooling and water cooling support. Able to support 360mm AIO coolers at the front and top, or a maximum height of 180mm for CPU tower coolers. Furthermore, supporting graphic cards of up to 400mm length and 190mm width, with a 240mm clearance for PSU. It is also compatible with any flagship 4090 GPUs.
In addition, the AIR 903 not only supports True E-ATX form factors, but also SSI-EEB motherboards. Featuring 5 SSD and 2 HDD drive bays, as well as an USB TYPE-C port and USB 3.0 ports.
Easy Cable Management
In order to provide users with a user-friendly cable management system and easy access, the AIR 903 series features a spacious 27mm cable route with rubber grommets and velcro straps.
MONTECH AIR 903 features a GPU clearance of 400mm in length and 190mm in width for maximum capacity. All PCIe slot covers can be removed to install MONTECH’s vertical GPU mounting kit sold separately.
https://www.montechpc.com/en/products_detail.php?nid=305&s_ok2=
MSRP
AIR 903 BASE
Black
$65
White
$69
AIR 903 MAX
Black
$75
White
$79
AIR 903 BASE
Specifications
Pre-installed Fan
3 x 140mm PWM Fans
Motherboard Support
E-ATX(SSI-EEB, SSI-CEB)/ATX/Micro ATX/ Mini ITX
Radiator Support
Top: 360/280/240/120; Front: 360/280/240/120; Rear: 120
Clearance
GPU:400; CPU:180; PSU:240
Expansion Slots
7
Drive Bays
SSD:5 ; HDD:2
Fan Support
Total 9 Fans
AIR 903 MAX
Specifications
Pre-installed Fan
140mm ARGB PWM x 3 + 140mm PWM x 1
Motherboard Support
E-ATX(SSI-EEB, SSI-CEB)/ ATX/ Micro ATX/ Mini ITX
Radiator Support
Clearance
Expansion Slots
7
Drive Bays
SSD:5 ; HDD:2
Fan Support
Total 9 Fans
Available on Amazon:
AIR 903 BASE (black): www.amazon.com/dp/B0C98RFQXJ
AIR 903 BASE (white): www.amazon.com/dp/B0C98TR925
AIR 903 MAX (black): www.amazon.com/dp/B0C98RRPXL
AIR 903 MAX (white): www.amazon.com/dp/B0C98SZCSG
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,230 messages 225 likes
Montech just launched the AIR 903 BASE and AIR 903 MAX mid-tower chassis. With a focus on airflow, the AIR 903 BASE features three pre-installed 140 mm PWM fans. The MAX comes with four, three addressable RGB at the front and a non-ARGB at the rear. These mid-tower chassis are capable of housing large E-ATX motherboards and "any flagship RTX 4090 GPU". Pricing starts at just $65 for BASE model in black. With the most expensive model, the white MAX, at only $79, these are priced to be within anyone's budget.
Click here to read more!
Reply Like
