Phanteks
Table of Contents
Phanteks has just launched its latest chassis, the Enthoo Pro 2 Server Edition. Built on the Enthoo Pro 2 platform, the Server Edition allows for up to 11 PCI devices for massive computing capability. Additionally, there is SSI-EEB motherboard compatibility and room for multiple storage devices. Two versions are available, a solid side panel model with an MSRP of $159.99 and a Tempered Glass version for $169.99. The Enthoo Pro 2 Server Edition chassis is slated to be available sometime this month.
PHANTEKS LAUNCHES THE ENTHOO PRO 2 SERVER EDITION:
UNPARALLELED PERFORMANCE AND VERSATILITY
Rotterdam, The Netherlands – July 11th, 2023 – Phanteks is excited to announce the launch of the Enthoo Pro 2 Server Edition, designed to deliver unparalleled performance and versatility. With innovative features like Phanteks “High-performance Fabric” and a spacious interior, the Enthoo Pro 2 Server Edition can accommodate any high-end configuration whether its SSI-EEB motherboards, extreme water cooling, or extensive storage requirements.
Phanteks Enthoo Pro 2 Server Edition
With support for both consumer and server-grade hardware, the Enthoo Pro 2 Server Edition enables the seamless integration of diverse components, allowing users to build a cost-efficient server system that meets their specific requirements. The Pro 2 Server Edition expands support for more PCIe devices, accommodating server-grade hardware and providing exceptional cooling options for optimal performance. The additional left-side fan bracket provides additional direct cooling for the most extreme server builds.
The Enthoo Pro 2 Server Edition offers extensive expansion capabilities with up to 11 PCI slots available allowing for the installation of multiple expansion cards, providing users with the freedom to customize their server setup to their liking.
With its exceptional performance capabilities, unmatched compatibility, and extensive storage options, we believe the Enthoo Pro 2 Server Edition will empower professionals and enthusiasts alike to create powerful server systems without compromise.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Marking their first foray into the AIO market, Phanteks has announced the Glacier One all-in-one CPU cooler line. The new coolers will be available in 240mm, 280mm, and 360mm versions. The Glacier One features Asetek’s Gen7 water pump along with a tempered glass infinity mirror pump cap using D-RGB lighting. The pump cap will also serve to hide the mounting hardware creating a clean installation. Additionally, Phanteks has made improvements to it’s MP series radiator fans for higher speeds and increased static pressure. MSRP starts at $124 for the AIOs and is available in black or white. Here is the official news from Phanteks.
Phanteks revealed several new cases, power supplies, fans, and more at this year’s CES event. Headlining Phantek’s coverage is the Evolv Shift XT mini-ITX chassis and Revolt SFX power supply. These small form factor components provide a powerful platform for the smallest builds. Also announced today are the White Edition Evolv X and Eclipse P600S cases, SK PWM D-RGB series fans, and AMP series power supplies. Phanteks was kind enough to include pricing and expected availability for all of its new products. Below is Phanteks product coverage.
Phanteks was founded in 2007. Their first product was a heatsink that was arguably the best heatsink when it was introduced. Since then we have seen more fans and more heatsinks from Phanteks. And now they jump into the world of cases. Just as they did with the PH-TC14PE, Phanteks is starting at the top end of the market, this time with the Enthoo Primo, a $250 case. Is this case worth that price? Let us find out.
Neat idea, but apparently only a "compute" server, I didn't see that much room for additional HDDs. I'd consider 10 drives minimum to quality for a "server" chassis.
edit: I see one screenshot that has about 8 drives in there, I assume those are normal 3.5'' HDDs and not 2.5'' SSD-size. So not bad, but I guess I'd need to see if it has any sort of a backplane or anything to help power the slots and such as well.
double edit: found this elsewhere:
"For storage capacity, there are no compromises with up to fifteen drives including four 3.5″ HDDs and eleven 2.5″ SSDs plus this capacity can be increased up to 21 with additional HDD cages sold separately."
Overall not bad, especially for a tower-shaped chassis.
Right. I was looking to see how many drive bays it supported but was unable to find any info on it. It wasn't in the PR and the Phanteks website doesn't list it yet. :shrug:
@Blaylock - info is already on their website - https://www.phanteks.com/Enthoo-Pro2-Server.html 10x 3.5" HDD/SSD or 11x 2.5" HDD/SSD. Somehow I see there are 13 spots for 2.5", but maybe I missed something. Probably there are no brackets for 2.5" in the additional 2x 3.5" bays on the bottom.
At least in my experience, most clients buy "small" servers with 4-8 HDD/SSD, so it should be more than enough. More often, servers use 1-2 M.2/PCIe SSD, so even fewer SATA/SAS drives are in use.
A typical 1U/2U rack server has 4-8 3.5" HDD or 8-12x 2.5" HDD/SSD bays.
I like the idea that you can easily install multiple long PCIe cards and still have enough space for at least 8x HDD/SSD. 2x 3.5" spots on the bottom may interfere with long PSUs or their cables. In most cases that I have, drive bays near PSU are removed as they cause problems with installation. On pictures, almost all manufacturers show installation without cables and try to install there 1000W+ PSU with all the cables, so they won't have anything on the way.
Glad to see Phanteks has since posted the info. The other question I had was whether or not the case was SSI-EEB AND E-ATX compatible and it looks like it is. This seems like a very capable case for anyone running a decent home server that doesn't want to deal with a 1U/2U rack.
I also agree with you about the HDD cage at the bottom. The PSU cables make it all but unusable. The best-case scenario is it's a nightmare to build in with that bottom cage installed. But to be honest I'd rather have the option than not have it.
Loading new replies...
1
1
1
1
