On March 29, 2020, Corsair quietly announced a recall of recently manufactured SF series small form factor power supplies. After receiving greater than normal RMA rates they conducted an internal investigation and decided to recall the units manufactured between October 2019 and March 2020. Not only are they offering a full replacement for the affected units, but they are also offering the replacements in advance. Here is the quote from the Corsair Forums.
To CORSAIR Customers
We have recently identified higher-than normal RMA rates among our SF family of small-form-factor PSUs. Following a thorough investigation, we have found a potential issue that can manifest when the PSU is exposed to a combination of both high temperatures, and high humidity. This regrettably can cause the PSU to fail. This issue potentially affects units in lot codes 194448xx to 201148xx, manufactured between October 2019 and March 2020
This problem can be apparent as soon as the unit is powered on for the first time, or manifest over time as the unit is exposed to a range of environmental conditions. We want to reassure customers that impacted units in no way risk damage to the components and hardware connected to your SF series PSU. This fault can occur only on the primary side of the PSU and is entirely isolated from the DC side of the PSU’s transformer that delivers power to your PC’s hardware.
While this issue does not, and will not, impact every unit manufactured within this time, out of an abundance of caution and commitment to the quality of the SF-Series, we are starting a voluntary product replacement program for owners of SF PSUs within this lot code range.
Impacted customers can submit a ticket at the below form, with the Subject “SF Series voluntary product replacement,” if they wish to replace their potentially affected power supply
https://help.corsair.com/hc/en-us/re…d=360000914791
Our pre-paid Advanced RMA process will be available for customers which need to minimize downtime and disruption. The originally purchased unit will need to be returned to CORSAIR, at our expense.
We wish to reiterate that only SF Series PSUs in lot codes 194448xx to 201148xx, manufactured between October 2019 and March 2020, are potentially affected. All SF-series PSUs purchased before October 2019 are not affected. You can identify your PSU’s lot code by referring to its packaging, or the serial number sticker on power supply’s side.
We understand that the replacement of a PSU is a disruptive process and while only a small percentage of units will be affected with no risk to end user components, we feel this is the right decision to ensure concerned customers that their PC is powered by a PSU with the reliability and quality they expect from CORSAIR.
Many Thanks,
CORSAIR Customer Service Team
It is great to see a manufacturer be proactive rather than reactive with recalls, especially with a product like a power supply. If you own an SF series power supply with lot codes ranging from 194448xx to 201148xx you can click on this link to submit a ticket. You will also need to include “SF Series voluntary product replacement” in the subject line.
Discussion
I love that they are covering all shipping cost and sending out the PSU's in advance to minimize user downtime. To me this says a lot about their commitment to customer satisfaction. Basically raising their hand, admitting they screwed something up, and are doing everything they can to make it as right as possible.
Conversely, I also think it's a smaller number of units affected than if it was, say, their RM line. Hopefully they would have handled it the same, but I do have my doubts.
Agreed 100%. I like to see a company step up properly. Pre-shipping and covering shipping is a big cost and risk to them. I remember trying to RMA an ek product which became such a PITA that I finally gave up. Good to see my Corsair loyalty is deserved...at least right now.
Yeah I noticed that. Was more just a curiosity, like if it's a section that wasn't soldered right and is failing at under harsh but still normal conditions.
My Corsair AX1200 has been going strong for 8 years now... Never heard of a questionable series from them.
