G.Skill has recently announced the release of the DDR4-4400 CL17 Trident Z Royale kits available in 16GB and 8GB modules. With timings of CL17-18-18-38, these memory kits combine high speed with low latency. Here is the official press release from G.Skill.
(12 June 2020) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is releasing new extreme-speed DDR4 memory kits that push 16GB and 8GB modules up to DDR4-4400 with a low latency of CL17-18-18-38 across the board, under the Trident Z Royal family. Upgrading specifications across all three fronts of memory frequency speed, module capacity, and low memory latency, these specifications are engineered with Samsung B-die ICs and designed for the latest Intel Z490 platform to achieve higher performance for gaming and content creation.
The High-Speed, Low-Latency Challenge with 16GBx2
As 32GB memory total capacity becomes the standard for gaming PC and performance PC builds, G.SKILL recognizes the importance of extreme performance 16GBx2 memory kit configurations. Rising to the challenge, G.SKILL has created the DDR4-4400 CL17-18-18-38 memory kit with 32GB (16GBx2) capacity under the Trident Z Royal family. See the memory kit stress testing on the MSI MPG Z490 GAMING PLUS motherboard with an Intel® Core™ i5-10600K processor in the screenshot below.
Additionally, the same DDR4-4400 CL17-18-18-38 32GB (16GBx2) memory kit is seen tested on the ASRock Z490 AQUA motherboard and the Intel® Core™ i9-10900K processor in the screenshot below.
Achieving CL17 Low-Latency with DDR4-4400 8GBx2
At the same time, G.SKILL is also lowering the memory latency of 16GB (8GBx2) kits at DDR4-4400 to CL17-18-18-38. As seen in the screenshot below, the memory kit is validated on the ASUS ROG MAXIMUS XII FORMULA motherboard, based on the Intel Z490 chipset, with the Intel® Core™ i9-10900K processor.
Specifications & Availability
These high-speed, low-latency Trident Z Royal memory specifications will be available via G.SKILL worldwide distribution partners in Q3 2020.
About G.SKILL
Established in 1989 by PC hardware enthusiasts, G.SKILL specializes in high performance memory, SSD products, and gaming peripherals designed for PC gamers and enthusiasts around the world. Combining technical innovation and rock solid quality through our in-house testing lab and talented R&D team, G.SKILL continues to create record-breaking memory for each generation of hardware and hold the no. 1 brand title in overclocking memory.
Discussion
I second that! I miss the days of getting nice ram without all the added lights and flashy heat spreaders. It's the primary reason I went with my Team Group ram when buying B-die: nothing fancy, just good ram. I'll gladly pay for clocks just not the lights and other nonsense. It would be nice to see companies like Mushkin get some better clocks and timings with their simple clean looks.
On the other hand, where will you use any higher frequency RAM? AMD is not scaling well past ~3600 and Intel has barely any improvement gains past ~4266. I guess that high-frequency RAM will have more point when or AMD bumps 1:1 IF ratio to let's say 2500MHz or we will see DDR5.
Mushkin is out of the enthusiast market since ... early DDR3. They had nothing after their last Elpida kits. I can even say they started to disappear when Micron D9 DDR2 problems started and because of too high RMA rate, they replaced their whole memory line with different IC.
B-die is only in 8GB and 16GB modules and is harder to set at a higher frequency than the new Hynix or Micron IC. Since they're not manufactured anymore, then these kits usually cost a lot and whatever left will be replaced soon. I even wonder if these memory kits in the news will appear in stores as many of these top kits are like vaporware. A lot of noise in press releases and later you can't find them in stores and go EOL within some weeks, or never appear on the website's product list.
https://www.newegg.com/patriot-16gb-288-pin-ddr4-sdram/p/N82E16820225144
https://www.overclockers.com/forums/showthread.php/792517-Team-Group-Xtreem-SE-16GB-DDR4-4133-C18?p=8094689
This kit should run pretty well but I didn't have the luck to mine. Even though it was overclocking till some point then pretty much every other brand Samsung B 4000+ memory that I had, was overclocking better, including mentioned earlier Patriot Steel which is also cheaper. There are some users on the forums who had much more luck with this specific memory kit so it's not a rule.
As far as Team Group memory, I have mixed feelings about them. Some of their kits run great, some are already at the edge of stability with their XMP profiles.
Probably today will arrive Team Group Dark Pro 2x16GB 3600 16-16-16 on Samsung B. I rarely buy memory kits in the last months as I just can't afford to keep buying RAM but this one was at a reasonable price and I wanted 2x16GB Samsung B kit so I made an exception.
Another thing is that for gaming+additional stuff at the same time, 16GB is starting to be a minimum. When I run a game and some more things in the background then I reach 12GB+. Sometimes I have a game in the background and I run photoshop to edit some larger photos and then it passes 16GB.
In general, most higher G.Skill kits are on Samsung B too but I'm not sure if you are looking for a well-overclocking kit or just something that has a high XMP profile and looks well without the RGB.
In some stores are still available TridentZ black/red 3600 15-15-15 1.35V and their price is maybe not low but lower than most 3600 CL16 or 3200 CL14 kits. I mean F4-3600C15D-16GTZ. These kits are on the best Samsung IC. As you can see, new 3600 14-15-15 or 3800 14-16-16 kits require 1.45-1.55V and cost significantly more, maybe because of RGB.
My plan is to keep a couple good B-die sets around. Right now I'm primarily looking for a high XMP set of B-die to test my setup. So far I think it is the memory controller limiting me because multiple sets have not overclocked well. Only one was B-die though so not sure with my current Team Group B-dies since no matter what I set them to they seem maxed out where they are at 3600 15,15,15. On the other hand my current sticks could fall into that category of Team Group that is maxed out already you speak of. It's more curiosity for me at this point, not so much if I get gains in performance or not. Thanks for the info.
Intel Comet Lake-S is so far really disappointing in memory overclocking. Most motherboards have some weird clock walls or can't run at CR1 at 3600 or above. On the other hand, AMD is scaling well only on the IF ratio 1:1. It's fun to OC till 5000+ but performance in benchmarks is quite disappointing when you can achieve about the same at 3600 and 4600+.
From higher XMP still on Samsung IC there are almost only G.Skill kits. Most other brands (also including G.Skill) are releasing new 4000+ kits at Micron/Spectek or Hynix IC. Seems cheaper and easier to make. G.Skill TridentZ 4266 CL19-19-19 should be still available at a reasonable price and it will be Samsung but at least my experience is that the same can be found in 3200 14-14-14 or 3600 16-16-16 kits which are cheaper.
