- Jun 30, 2004
- San Antonio, Texas
no thats just the amount of time in which they will replace or repair if it breaks. Properly taken care of they should last a very very long time.
Its a free maintenance kit. Its just basically a slow death till the pump dies to put it in laymens terms. Only thing you can do is remove the dust from the rad fins, make sure the fans and pump still run and make sure you got some good past under the block. I think that's all you can do.
I concur. An AIO cooler is designed specifically to just "set and forget". No need for regular maintenance as with a custom loop ( aside from what Jack just mentioned). By the time the fluid inside evaporates the pump will be long dead.
You can always mod it like so , but then it won't be maintenance free.
Didn't expected you can actually remove the old piping and change it to another one...but i do hate this original pipping , im using an Enermax AIO but same piping as this Corsair you shown me , it's very solid....not flex to it , i wonder is it it good , i feel unsafe for it feels like it break easily since it's so " stiff " instead flexible like most new AIO Coolers , even Corsair have move to flexible piping on their new coolers......
But the coolant , I could use those full water cooling coolant for it then ?
Are they same with automotive coolants ?
The coolant inside the AIO is a mixture of some sort to prevent rust/corrosion as they're mixing metals; copper plate on the pump/block assembly and aluminum for the rad.
If you're going to mod the one you're using by the link I posted, I suggest you use some sort of anti corrosion fluid mixed with distilled water.
Well that sounds exactly like automotive radiator coolant , they are actually anti rust and anti freeze , they are usually made from either Ethylene Glycol and Propylene Glycol.
I should have gotten the Swiftech H220 AIO Cooler , i only found out we actually import them right after i bought my Enermax....
You can actually drain the radiator , even change the tubing if you want to. They made it sort of like a normal water cooler instead a of a sealed up type like ours
Basically its kinda like an AIO Cooler but is maintainable ?
http://www.swiftech.com/h220.aspx#tab2
And add more to it. (ie. reservior, radiators, waterblocks etc) Just like Gabe said (Swiftech CEO), its to fill in the gap between a AIO and a custom water cooling loop.
@Nebulous
That was a great link to the Corsair mod you provided, and has given me some ideas down the road once my warranty is up.
Just saw the most recent poll numbers here. Wow I never would have guessed that water had become almost the majority pick. I almost think it's worth breaking AIO/Custom into their own categories, since there is a massive difference in the amount of cost/labor/performance associated with each.
