- Oct 9, 2003
- Illinois
Humm mine reads (after flashing)
0 1.1v
1 1.2v
2 1.4v
3 1.5v
0 1.1v
1 1.2v
2 1.4v
3 1.5v
gigabit said:Voltage level 2 at 1.4 is the 3D voltage,So RT should read 1.4vid core when run 3D aps
gigabit said:No dont return it you got what you paid for a very good card even if it wont modded it will score 10,00 in 3D03 stock.Just try didnt pipes and shaders til you find out what one is bad.Then either me or shuiends can write you a custom script to unlock what good from the bio's.But right now i dont totally get the script writting but shuiends does and i think would be more than happy to help u out.Just pm him or me if you wanna find out what he will need from you to do it..Then you can sell it as a modded card get what you paid for and buy another if you want.But dont rma it you got what you paid for and if nvidia starts getting to many rmas(just because it wasnt moddable) the 6800nu might not be produced any more and that would suck.It aint like you bought the card and the store said i guarente this card will unlock if not return it.Also my core cant touch 420 either but my card is awesome so try backing down on the core.and see if that helps if not flash it back.But just because it wont do 420 dont mean any thing is bust.Sorry for rattling on but i do get upset sometimes about questions like this.I mean i know it aint what you hoped for but thebn you should have spent a few xtra bucks and got a 6800GT,The mod is a bomus some get some dont but almost every one gets one or the other
My fault .Im sorry about that.I was in a bad mood yesterday.But even for a Gt you still have a decent OC and i still say you got what you paid for,Unless its a gainward GS and your told it will OC to a certian point you got what you paid and more.And even the GS's i dont think are guarenteed to hit 420.I just checked they are only guarenteed to 400/1100Whats a BFG 6800GT OC come clocked at?Do they gaurentee a certain higher clock speed?.I do know BFG has a pretty good tech line they helped me with my BFG fx 5900 when i frist bought it.mR|bUNgLe said:see sig...
Im running a GT which is why I think somethings wrong. a NU well Id understand that to not hit 420 @ 1.4V but a GT with awesome temps?
oops must have posted in wrong thread thought flashing 6800s meant all versions
CandymanCan said:Its does, you can flash the NU GT's Ultra's ect ect.
Btw 430/1.5 is a good overclock on GT so why are you complaining if you are ? Atleast youre luckier then some people, i know guy who has a GT that only ocs to 400/1140.....
What are youre temps with that DD Nv68 on thier ? I mounted my cpu DD maze 3 on my video card and my temps are 39-40 Idle and about 46c Load.
Mustanley said:yes it does. But why does it say 128bit memory bus? It benches like a 256bit card.
$ffffffffff NVIDIA specific display adapter information
$ffffffffff ---------------------------------------------------
$0100000000 Graphics core : NV41 revision A2 (12x1,5vp)
$0100000001 Hardwired ID : 00c0 (ROM strapped to 00c1)
$0100000002 Memory bus : 128-bit
$0100000003 Memory type : DDR (RAM configuration 01)
$0100000004 Memory amount : 262144KB
$0100000005 Core clock : 324.000MHz
$0100000006 Memory clock : 299.250MHz (598.500MHz effective)
$0100000007 Reference clock : 27.000MHz
