ColtIce
Disabled
- Nov 20, 2002
- 9 months 43202 summer months 98951
I took too long with my post on how to do it but yeah those are artifacts for sure.oh well the info is there if anyone else needs it.
Is this what you're looking for, my default pipes and whatnot?the adam said:So if ppl would pm me or post on the forum their units that were locked, that would be great.
Ok that script(the one provide in RT)for software masked bios which i would say only 3% of the cards out are software masked. if you have ran RT and found that you can unlock all the pipes and vp's then you can use this script here to mod your biosthinksnow said:Color me curious if you can post the instructions, folks. I found my NV40BIOSSwUnitsMaskElimintor folder, it has this insideWhere do I find the bios file to drop in the folder?
Impressive work, btw.
You dont wanna run 1.4 to long depending on temps i know it didnt help my card once i hit my max it was the same at 1.2 as at 1.4 just hotter..And the rest of what you said is right .If your having no aritfacts now you can flash it now you have tested enough to know if you anyproblems. Sounds like your good for the script thats posted in the thread and below if you wanna copy it here..And just to let you know i can OC to 410/900 but my score's dont get any better after 385/820 even with 1.4 v but my temps went over 76c after like 10 minutes playing far cry.But your card has a better h/s but i still wouldnt chance 1.4 unless you only put it in the 3D and throttle only and idle at 1.2vPCGUY112887 said:Yes that is how I was lead to this thread... i'm trying to find my max's before I go and flash. The script listed on that page is for the hardware locked ones right? Also I should be able to rip my BIOS from my card, come in and add the script then mod it to 1.4v at whatever clocks I want then flash the card correct?
So far i've been able to get 375/830 stable at 1.3v, I wonder what I can get at 1.4
