I don't know. Those VRMs are blocked by a heat BARRIER. Why barrier, becausehttps://tech4gamers.com/gigabyte-ultra-durable-z370-hd3-motherboard-review/
"The motherboard seems to be using 4+3 power phases." Just looking at the board it also seems to me that the VRM heatsink is rather modest. I wonder if putting a fan on it would help.
These testers were able to get an 8700k to 5.0 ghz on 1.35 volts. They (and others) describe it as a "budget friendly board". And this has always been the case with Gigabytes HD3 series boards.
Don't really know why it's like that. But OP complained about it, and so did OC3D on his channel.I had the even lower end Gigabyte Z370P D3 a while back and ran an i7-8700K @ 5 GHz without any problems. Even though my delidded chip wasn't the best and needed 1.425V to run at 5 GHz, the VRMs were not an issue.
The heatsink feels hot to the touch. I can't place my finger on it for more than a second or so. 98c VRM is hot, but again, this is the peak temperature after 1h of P95. during 24/7 uses, it runs at about half this temperature.You can also just place a spot fan to cool the VRM. Even if the throttle temp of the VRM is 120c, I would not run it that hot for extended periods. 98c is still hot. Have you checked the contact between the VRM heat sink and the components. Makes me wonder if there is poor contact.
Don't count on getting more overclock because you delid. That only helps if voltage is holding you back. Every CPU has a wall that you can't get beyond by adding more voltage, at least until you move to extreme cooling like LN. What's your vcore now?
OK, I think I'm starting to understand how to properly set the voltages on this board, and I figured out why I had difficulties in the past.Load voltages are lower because of vdroop. That's normal. There should be a setting in bios called LLC (Load Line Calibration) that buoys the CPU voltage under load to offset that tendency.
