What plug is it in?
Gotcha. The black ports are SATA II 3G, btw, I think that was just a typo in your previous post that threw me off.
Try switching the HDD that isn't being recognized to a black SATA II 3G port. If it doesn't show up then, I'd try downloading SeaTools for DOS and checking the drive with it. I had a flaky WD Caviar Blue that would sometimes show up and sometimes not, it ended up needing an RMA.
Or one of the critical updates fixed a bug that stopped certain hard drives from showing up in disk management...seems like a more logical solution to me.
Windows Update still works in that 30 day grace period, by the way, you can update before you activate.
Nope. Bad assumption, thats a leap of faith you took that didnt work out.Apparently, Windows does NOW require you to activate and download critical updates BEFORE you're given full access, function, and features.
Edition? Edition of what?
The last time I installed Windows was probably two weeks ago, lol. After I spend much time modding several instillation ISOs into a single all-in-one installation disk for every version of Windows 7, both 32 and 64 bit.
I frequently reimage machines for family and whatnot, activation is usually the last thing I do. Updates and common software is almost always done first.
I am 100% sure that typing "Windows Update" in the start menu search bard, hitting enter, clicking check for updates, and clicking install updates works completely without activating windows.
If they're both fairly new machines and you plug an Ethernet cable into both, the network controllers should detect it's connected to another computer and switch to crossover mode, they should show up as drives in each other's Explorers. Or you can just use a crossover cable if you happen to have one on hand.
The other method would be to take the laptop hard drive out and just plug it into your desktop, SATAs plenty fast. xP. Assuming your laptop doesn't have an IDE drive in it.
Only reason I'm on OSX right now is because the only other operation rig in the house has a 4000RPM Delta as the back exhaust (I didn't have anything else on hand) and you can only sit next to that thing for so long, lol.
That rig is actually a quad core AMD APU with a 6670 in Hybrid Crossfire...whole build was less than $500 xD. The case only came with one intake and it was getting rather hot, so I just threw whatever spare fan I had in there...it just happened to be really loud.
I tried putting a cheap fan controller I had in there... 8W controller didn't like a 19W fan very much.
