A few more bench results. Comparisons of 3DMark physics. Article seems a little odd borrowing scores from here and there but it is what it is http://wccftech.com/amd-ryzen-3dmark-benchmarks-leaked-faster-core-intels-i7-6950x/
My favorite part about these is they pretty much confirm that the boost clocks are not in use yet. The performance they show at 4 ghz means the stock chip is running at 3.4 not 3.8, meaning the 300-400 dollar procs are a fair clip better than the 6900k at much reduced price (in this work load, but it seems to be a trend if not true for everything). With boost the 4c will fall just short of the 7700k. If all chips OC to 4 ghz then an OC 4c/8t looks like a 7700k at stock. If the 4 cores go to 4.5 ghz, then they are almost equal performance in an overclockers eyes (but more fun ) for probably half the price.
So in the end, it has more cores while costing less. Since most don't use more than 4c/8t, the core argument, in my mind, isn't an argument (unless you use them of course). So, AMD seems to finally match performance and goes under on price..
W00t!
Curiosity, do they turn the Turbo/auto-overclock off in these benchs ? would the 6950X be running at 3ghz stock or 3.5ghz turbo ?
Yes but there would still be an "inflation" of the benchs if some of the cores decided to up to 3.1ghz-3.5ghz even for a few seconds. If so the numbers aren't exactly trustworthy ?
Side note: anyone know how XFR will handle 'better cooling'? Is it still going to behave as turbo boost does, or is it deeper. I haven't dived deep into their announcement from CES, but I do recall seeing stuff about auto overclocking.
So we are looking at more like a base clock adjustment, IE all cores can be boosted at a given time?Read into the actual tech, it's much deeper than normal turbo.
I need to stop looking into ryzen so much and spend more time working on me EE classes [emoji14]
Additionally, AMD introduced SenseMI, a set of sensing, adapting, and learning technologies built into the AMD Ryzen™ processor that combine with multiple other advances in architectural, platform, efficiency, and processing technology to address the demanding needs of gamers and enthusiast PC users.
