Although I don't see any good way to rinse her out without getting water all over the card.
How'd you rinse your 780 hydro?
Yes
Is it supposed to only go that far hand-tight and then the rest of the way with a vice grip?
Ah ok, so I do use tools to finish tightening it.
"It's my first time doing this"
It was mine too, I just wasn't comfortable with finger tightening either.
Those flats are an exact mm wrench size, but I forgot which one
Mmmm looks tasty
One thing, be sure to double-check flow direction through the CPU block.
Not sure if anyone mentioned that it does have a dedicated In and Out port.
Yep! The top-right port on the 2nd picture is labeled the Inlet port, and it's getting fed directly from the dual-bay res pump outlet
Yes! And for that I'm grateful!
Very thoughtful of EVGA
