All I ever did was swap chips - I don't even reset BIOS ...
Sweet! Thanks. OK - My two cheap 1 gb memory sticks (but with same timings) have run two passes of memtest386 at 250 Mhz with no errors. Failed at 255 Mhz, restarted test at vdimm 2.9, then decided against it since ram ran 250Mhz (DDR500) which is good enough. Knowing what we know about the board (passed 320 - tested today), Memory (passed 250) and previous overclock of 2.85 for the opty 165 I bought, I suppose I could start at previous chip owners overclock of 2.85GHz (316*9). What do you think QuietIce?
EDIT: I hate to say it, but it looks like my memory may hold me back. Looking at the Toledo overclock results I found two that got my attention:
OSA180DAA6CD CCBWE 0541 RPMW 2805 MHz (255.0 x11.0) 1.52 V memory 255 MHz 3.0-3-2- 6 1T 2.80 V LDT x4.0 (QuietIce) details
OSA170DAA6CD CCBWE 0546 XPMW 2600 MHz (260.0 x10.0) 1.45 V memory 185 MHz 2.0-4-4- 8 1T 2.60 V LDT x3.0 (runsalone) details
250 is probably the limit of my RAM, but maybe lossening timing, upping vdimm might help, but it is going to be pushing it to say the least. If I set bios to 290x10, what ram speed and HT settings will keep RAM at 250 or less?
Math challenged.
It looks to me (with the memory I have now) like I should set memory to 133 to start, HT to 3, FSB anywhere from 280 to 320 starting at 280 for openers, CPU Multiplier of 10. Is this correct?
My chipset has always been hard to cool. I have a Zalman passive chipset cooler now with a case fan mounted over it. Still runs warm. May decide to put an active cooler on it. At 320 FSB chipset was 53C. Case was open and I had a box fan sitting near it so I am running Prime95 test at 320 with box fan blowing into the open case
. I also have a Kamabay front case CDROM slots fan installed. I could put a faster fan in that mother also - 800 CFM in it now. CPU cooler runs great - no problems. Any suggestions?
