Alright, got in a lot of trouble but got out of it with a bios reset. Board is back to the day it was born. Everything was hunky dory at 310x9. Decided to push it up to 333x9 and post reappeared telling me to reduce the cpu clock and that it was running in some sort of MB safe mode. However, when I tried to enter bios to reset, box went nuts, monitor said "unsupported mode", motherboard displayed error code 26 on led. After fiddling around for a while I could get post to display for a 30-40 seconds and get into bios - then video would go nuts and that would be the end of it.
There were only two jumpers on the board that looked like bios reset, and the second set of jumpers I tried reset the bios. How I'll update the bios I don't know, but I'll worry about that later. EPOX still has a website, but the bios download wants a FTP user name and password and doesn't like the user name and password EPOX's site gave me so I emailed them and who knows?
Board ran prime95 at 333 fine as a test, memory was no where near the top end, and I don't know why the bios didn't like 9x333. I had the voltage on the CPU pumped up to 1.47 or so for 333 attempt, but that was a .25 (or is it .025? anyway) volt increase over the setting I had used for successful 310x9 prime95 test. Wasn't near max.
Aside from losing the bios updates, what do you think QuiteIce? Any thoughts on the video. I have a Gigabyte 7600GS budget video GPU normally running 450 GPU, 400 memory, like 256 MB video ram. HT was at 3 (maybe should have reduced to 2?). Memory voltage 2.7 or 2.8 - don't remember - but it ran memtest at 250. Memtest is not a system test however.
Right now box is a virgin running 1.8 - which isn't bad considering it wasn't running at all
EDIT: Couple of other things happened. At 300 or 310 box ran chksk for some reason when I booted. I think at 310 1st attempt it said a windows file was missing. When I had trouble booting 310 I upped voltage slightly (maybe 1.41 or 1.45 or so) and it booted fine and ran prime ok. That's when I decided to try 333 and BOOM!
