Ha ha... my bad, I thought you had a bunch of intakes. Leave it as is as you will disrupt airFLOW. Proper airflow means more than negative/positive pressure.
Here is the thing...You are not an extreme overclocker. You do not need every little degree to eeek out another 100Mhz in your overclock. If you flip the exhaust around you have poor airFLOW inside the case. Its just not worth it when the result of it is essentially meaningless.
1. No.
2. No. Thats handled by your hard drive.
3. It improves rendering of videos if you are MAKING the video, not watching it. It will improve encoding times, some games will respond to increased speed as well.
alrite.. so to my knowledge, it is good for speeding up minor things or just to have the joy of seeing those numbers rise or trying to break some sort of record...
There are plenty of benefits to overclocking. Overall system response is faster. Overclocking started out as a poor man's way to get the performance of faster chips. So you buy the $100 2Ghz chip and overclock it to the $300 2.8Ghz chip for example.
..... I guess you guys dont understand the intensity of games like minecraft.. you show me a game when every single particle is an interactive item....
