So were you idling at 95% cpu usage then too? 106c on Mainboard just seems Outlandish.
AISuite is famous for causing problems.
Sometimes old habits block solutions. You need to confirm those high temp spikes are actually happening. If they actually happened and happened at idle something is using a lot of CPU slices in the background. Did you check processes in taskmanager to identify what is causing that? What about startup?
Funny how everyone keys in on the 106 reading but seemingly missed the -117 min reading while the CPU min was 18.5. CPUID is known to give false readings, especially on AMD FX chips.
Use AMDOverdrive instead to monitor temps. Some of those readings from HWMonitor Pro are obviously incorrect. The package temp looks about right, however. Are those max temps under sustained full load? Say Prime95 for 20 minutes?
Tgis is what I would try for temps. I never had a problem with HWMonitor on my FX, but idle/ low load temp readings on the FX chips has always been off. It's the nature of the beast. The package temp has been all over the board, too. For an FX try AMDOverdrive and just check the temp under load. Idle temps are a mystery on the FX. Fortunately, unless you have a major hardware/cooling problem they don't matter.
That's because there is only 1 temp sensor, not 1 for each core.All your cores being EXACTLY the same temperature down to a hundreth of a degree seems unrealistic as well.
