Arctic Silver 5 isn't really that good of a paste (if you were referring to AS5, if you were referring to Ceramique, it's even worse), it's been probably ~5-6 years since AS5 was among the top pastes (or more). Arctic Cooling MX-2 or MX-4, and Prolimatech PK-2 beat it in performance and easier clean up (and they aren't electrically conductive or capacitive), among other pastes.
Checking the CPU temperature in the BIOS of the motherboard isn't really a good test. The BIOS itself isn't putting much of a load on the CPU, so this isn't a relevant test since what we're interested in is core temperatures under full load (and the BIOS normally gives the socket temp as far as I know).
1-3 deg higher than others does not make it a bad paste
Is the best way to set it back to the Intel Q9400 CPU back to the stock speed of 2.00Ghz by rebooting and going into the BIOS?
Yes. When in bios hit the "hot key" for restoring the system to "optimized defaults". Usually it's the F5 key.
Is there any risk of me making my system unstable by putting the CPU back to the stock speed of 2.66Ghz?
No
Is it possible for me to damage the Intel Q9400 CPU by putting it back to the stock speed?
No
Did you read my post about hitting the F5 key in bios to restore the system to optimized defaults? That will do what you want to do.
Since you asked me, GreatUSA, I agree with what trents said.Yes. When in bios hit the "hot key" for restoring the system to "optimized defaults". Usually it's the F5 key.Is the best way to set it back to the Intel Q9400 CPU back to the stock speed of 2.00Ghz by rebooting and going into the BIOS?
NoIs there any risk of me making my system unstable by putting the CPU back to the stock speed of 2.66Ghz?
NoIs it possible for me to damage the Intel Q9400 CPU by putting it back to the stock speed?
My last question before I go ahead and make the change in the BIOS:
So as long as I only change the multiplier back to the original "x 8.0" from the current "x 6.0" there won't be any problems?
By doing this I'll just be restoring the Intel Q9400 back to what it was made to run at which was 2.66Ghz so there's no risk of me damaging the CPU or shortening its lifespan?
Is there anything I need to make sure I avoid doing so I don't damage the Intel Q9400 CPU?
