- Sep 27, 2003
I have a feeling that there isn't that much difference in timings (if there are any)... simply b/c the fact that lower frequency is usually tighter timings. If 1320mhz bios that we have is supposedly tighter timings, then my card wouldn't have hit 1600mhz so easy, which it just did earlier tonight.Senater_Cache said:does the GTX bios enable tighter ram timings or more options? does it enable higher quality settings in certain games? in other words why risk the flash?
I have a strong feeling it's the same timings, or VERY close if not.
*EDIT*
Just did a NIBITOR side-by-side check between the 7900gto bios (650/1320) and a downloaded 7900gtx SC (Superclock) bios (690/880) and the TIMINGS ARE IDENTICAL!!!
