eXtreme PSU Calculator update
eXtreme Power Supply Calculator update - 01/08/2008
January 8, 2008
The following changes were made:
Graphics Cards:
- added NVIDIA GeForce 8800 GT 256MB
- added NVIDIA GeForce 8800 GTS 512MB
- added ATI Radeon HD 3850 256MB
- added ATI Radeon HD 3850 512MB
- added ATI Radeon HD 3870
CPUs:
- added Intel Core 2 Duo E8200 2667 MHz Wolfdale
- added Intel Core 2 Duo E8400 3000 MHz Wolfdale
- added Intel Core 2 Duo E8500 3166 MHz Wolfdale
- added Intel Core 2 Quad Q9550 2833 MHz Yorkfield
- added Intel Core 2 Quad Q9450 2667 MHz Yorkfield
- added Intel Core 2 Quad Q9300 2500 MHz Yorkfield
- added AMD Phenom 9500 2200 MHz Agena
- added AMD Phenom 9550 2200 MHz Agena
- added AMD Phenom 9600 2300 MHz Agena
- added AMD Phenom 9650 2300 MHz Agena
- added AMD Phenom 9700 2400 MHz Agena
- added AMD Phenom 9900 2600 MHz Agena
eXtreme Power Supply Calculator Update - 3/12/2008
March 12, 2008
Graphics Cards:
- added NVIDIA GeForce 9600 GT
- added NVIDIA GeForce 8800 GT 1024MB
- added ATI Radeon HD 3870 X2
CPUs:
- added Intel Core 2 Duo E8190 2667 MHz Wolfdale
- added Intel Celeron E1200 1600 MHz Allendale
- added Intel Xeon E3110 3000 MHz Wolfdale
- added AMD Athlon X2 4850e 2500 MHz
- added AMD Sempron 64 3800+ 2200 MHz AM2 Manilla
- added AMD Sempron 64 3000+ EE 1600 MHz AM2 Manilla
- added AMD Sempron 64 3200+ EE 1800 MHz AM2 Manilla
- added AMD Sempron 64 3400+ EE 1800 MHz AM2 Manilla
- added AMD Sempron 64 3500+ EE 2000 MHz AM2 Manilla
- added AMD Sempron 64 LE-1100 1900 MHz AM2 Sparta
- added AMD Sempron 64 LE-1150 2000 MHz AM2 Sparta
- added AMD Sempron 64 LE-1200 2100 MHz AM2 Sparta
- added AMD Sempron 64 LE-1250 2200 MHz AM2 Sparta
- added AMD Sempron 64 LE-1300 2300 MHz AM2 Sparta
Pro version:
Added ability to select 3-Way SLI and Quad CrossFire X in Pro version.
eXtreme Power Supply Calculator Lite
Woah, my system uses alot less power then I thought. I know this thing doesnt take the place of actual hardware monitoring, but it says I can run my system off of a 300w psu...
The Lite calculator is quite accurate for my rig. It recommends 430W and my wall power from KillaWatt is 460W, steady state, fully loaded, at max OC in CPU and GPU. However, I would recommend plenty of extra reserve power to handle the big power transients that the 8800GTX puts on the system.
Well I'll tell you this: I sold dozens of systems with 8800GT a 400W HEC psu and a friend of mine was running the same one with a 8800GTS 640mb until last week but he moved to the Corsair 450VX because he wanted something quiet.
Don't get me wrong, I'm all for the Corsair VX/HX :beer:
Supposedly I need right around 570W for my system. Will have to break out the kill-a-watt tomorrow but I kinda doubt that figure is accurate.
You are configuring two 5430 quad processor chips? What motherboard are you planning to use? Where are you going to put the heatsinks? If you are going to overclock them, 650W could be reasonable...
no overclocking, the mobo will be an ASUS DSBV-DX heatsink where go in their normal spot... on the cpu :p
I could not find a CPU power spec for the 5430 but similar quads require, at most, 130W at spec speeds (2.66 GHz). You have no graphics card, so 650W seems to be a lot more than you need. Maybe the Power Calculator is uing incorrect data for the 5430.
I was just wondering, because Im running a 600w super flower aurora (Haven't read too much about it, the one review I did see said it wasn't the greatest), and was planning to switch to a PSU with 110v support (bought thi in switzerland, 230v only, going to go back to the US for college in a few months) and its good to know I wont have to be buying a 750w psu anytime soon :) .
And I put in my little project: needs a 92w PSU (don't have the 8400 in it, its 120w with it) :clap: and I bet its actually lower since it doesn't have a mobile/low power motherboard option. Got to love those mobile cpus :D
Intel Xeon E5430 2667 MHz Harpertown has 80W TDP, not 130W.
thanks
i configured
2x xeon 5430
4x2g bddr2 fbdimm
6x sata
1xdvdr/w
4x120mm fans
2x80mm fans
all at 100% usage and it gave me a raiting of 621watts, how accurate is it ? if i used a 650watt psu would that be enough ?
if 650 isnt enough which psu is best f rom the oens below ?
I suspect you used Quad Sockets for System Type, which means you have 4x Intel Xeon E5430 2667 MHz Harpertown. You need to select Dual Sockets as you have two processors.
I get 456W with your configuration, all at 100%.
April 9, 2008
Graphics Cards:
- added NVIDIA GeForce 9800 GX2
- added NVIDIA GeForce 9800 GTX
- added NVIDIA GeForce 8800 GS 384MB
- added ATI RADEON HD 3650 256MB
- added ATI RADEON HD 3650 512MB
- added ATI RADEON HD 3450
- added ATI RADEON HD 3470
CPUs:
- added AMD Phenom 8400 2100 MHz Toliman
- added AMD Phenom 8600 2300 MHz Toliman
- added AMD Phenom 9100e 1800 MHz Agena
- added AMD Phenom 9750 2400 MHz Agena
- added AMD Phenom 9850 2500 MHz Agena
- added AMD Athlon 64 X2 5400+ 2800 MHz AM2 Brisbane
- added Intel Xeon L5410 2333 MHz Harpertown
- added Intel Xeon L5420 2500 MHz Harpertown
- updated list of AMD Athlon 64 X2 processors for socket 939
TEC Coolers:
- added CoolIT Systems Freezone Elite
- added CoolIT Systems Boreas MTEC
WC Kits:
- added CoolIT Systems PURE CPU
psu wattage calculator
with all 100% and oc'd to 2.4 on the phenom... I ran a 431w...
I think some users are misunderstanding the (Dual/Quad "Sockets") option
True, very true. Before I had Single, Dual and Quad Processor listed but it seemed to confuse poeple a lot. So, I changed it to sockets. It helped, but still, there are some confusions.
What whould you suggest?
December 11, 2008
Sockets
- added Socket LGA1366
- added Socket Micro-FCBGA
CPUs
- added Intel Core i7 920 2667 MHz Bloomfield
- added Intel Core i7 940 2933 MHz Bloomfield
- added Intel Core i7 965 3200 MHz Bloomfield XE
- added Intel Atom 230 1600 MHz Diamondville
- added Intel Atom 330 1600 MHz Diamondville
Graphics Cards
- fixed NVIDIA GeForce 6200 power consumption data
Watercooling
- added Aqua Computer Aquastream XT Ultra USB Eheim pump - added XSPC X2O 150 pump
- added XSPC X2O 200 pump
- added XSPC X2O 750 pump
power supply wattage calculator
September 10, 2009
eXtreme Power Supply Calculator Mega Update
Graphics Cards:
- added ATI Radeon X1950 GT
WC Kits / TEC:
- added CoolIT Systems Domino A.L.C.
- added Cooler Master V10
CPUs:
- added Intel Core i7 860 2800 MHz Lynnfield
- added Intel Core i7 870 2930 MHz Lynnfield
- added Intel Core i5 750 2660 MHz Lynnfield
- added Intel Pentium Dual-Core E2210 2200 MHz Wolfdale-3M
- added Intel Pentium E6500 2930 MHz Wolfdale-3M
- added Intel Celeron 450 2200 MHz Conroe-L
- added Intel Celeron E1400 2000 MHz Allendale
- added Intel Celeron E1500 2200 MHz Allendale
- added Intel Celeron E1600 2400 MHz Allendale
- added Intel Celeron E3200 2400 MHz Wolfdale-3M
- added Intel Celeron E3300 2500 MHz Wolfdale-3M
- added Intel Xeon L3110 3000 MHz Wolfdale
- added Intel Xeon E3120 3166 MHz Wolfdale
- added Intel Xeon E3113 3000 MHz Wolfdale-CL
- added Intel Xeon L3014 2400 MHz Wolfdale-CL
- added Intel Xeon L5248 3000 MHz Wolfdale-DP
- added Intel Xeon L3360 2833 MHz Yorkfield
- added Intel Xeon X3380 3167 MHz Yorkfield
- added Intel Xeon W3503 2400 MHz Bloomfiel
- added Intel Xeon W3505 2530 MHz Bloomfield
- added Intel Xeon W3550 3060 MHz Bloomfield
- added Intel Xeon W3580 3330 MHz Bloomfield
- added Intel Xeon L3426 1860 MHz Gainestown
- added Intel Xeon X3430 2400 MHz Gainestown
- added Intel Xeon X3440 2530 MHz Gainestown
- added Intel Xeon X3450 2660 MHz Gainestown
- added Intel Xeon X3460 2800 MHz Gainestown
- added Intel Xeon X3470 2930 MHz Gainestown
- added Intel Xeon W5590 3330 MHz Gainestown
- added Intel Xeon L5530 2400 MHz Gainestown
- added AMD Sempron 140 2700 MHz Sargas
- added AMD Athlon 64 LE-1600 2200 MHz Orleans
- added AMD Athlon 64 LE-1620 2400 MHz Orleans
- added AMD Athlon 64 LE-1640 2600 MHz Orleans
- added AMD Athlon 64 LE-1640 2700 MHz Lima
- added AMD Athlon 64 LE-1660 2800 MHz Lima
- added Athlon II X2 240 2800 MHz Regor
- added Athlon II X2 245 2900 MHz Regor
- added Athlon II X2 250 3000 MHz Regor
- added AMD Phenom II X3 700e 2400 MHz Heka
- added AMD Phenom II X3 705e 2500 MHz Heka
- added AMD Phenom II X4 900e 2400 MHz Deneb
- added AMD Phenom II X4 905e 2500 MHz Deneb
- added AMD Phenom II X4 965 3400 MHz Deneb
- added AMD Opteron 1224 SE 3200 MHz Santa Ana
- added AMD Opteron 2350 HE 2000 MHz Barcelona
- added AMD Opteron 2352 2100 MHz Barcelona
- added AMD Opteron 2354 2200 MHz Barcelona
- added AMD Opteron 2356 2300 MHz Barcelona
- added AMD Opteron 2358 SE 2400 MHz Barcelona
- added AMD Opteron 2360 SE 2500 MHz Barcelona
- added AMD Opteron 2372 HE 2100 MHz Shanghai
- added AMD Opteron 2373 EE 2100 MHz Shanghai
- added AMD Opteron 2374 HE 2200 MHz Shanghai
- added AMD Opteron 2376 2300 MHz Shanghai
- added AMD Opteron 2376 HE 2300 MHz Shanghai
- added AMD Opteron 2377 EE 2300 MHz Shanghai
- added AMD Opteron 2378 2400 MHz Shanghai
- added AMD Opteron 2379 HE 2400 MHz Shanghai
- added AMD Opteron 2380 2500 MHz Shanghai
- added AMD Opteron 2381 HE 2500 MHz Shanghai
- added AMD Opteron 2382 2600 MHz Shanghai
- added AMD Opteron 2384 2700 MHz Shanghai
- added AMD Opteron 2386 SE 2800 MHz Shanghai
- added AMD Opteron 2387 2800 MHz Shanghai
- added AMD Opteron 2389 2900 MHz Shanghai
- added AMD Opteron 2393 SE 3100 MHz Shanghai
- added AMD Opteron 2419 EE 1800 MHz Istanbul
- added AMD Opteron 2423 HE 2000 MHz Istanbul
- added AMD Opteron 2425 HE 2100 MHz Istanbul
- added AMD Opteron 2427 2200 MHz Istanbul
- added AMD Opteron 2431 2400 MHz Istanbul
- added AMD Opteron 2435 2600 MHz Istanbul
- added AMD Opteron 2439 SE 2800 MHz Istanbul
- added AMD Opteron 8350 HE 2000 MHz Barcelona
- added AMD Opteron 8374 HE 2200 MHz Shanghai
- added AMD Opteron 8376 HE 2300 MHz Shanghai
- added AMD Opteron 8379 HE 2400 MHz Shanghai
- added AMD Opteron 8381 HE 2500 MHz Shanghai
- added AMD Opteron 8386 SE 2800 MHz Shanghai
- added AMD Opteron 8387 2800 MHz Shanghai
- added AMD Opteron 8389 2900 MHz Shanghai
- added AMD Opteron 8393 SE 3100 MHz Shanghai
- added AMD Opteron 8431 2400 MHz Istanbul
- added AMD Opteron 8435 2600 MHz Istanbul
- added AMD Opteron 8439 SE 2800 MHz Istanbul
