- Jan 12, 2012
I just re read my post sorry it wasn't clear, I meant can you run prime at the settings your at with the "case side panel" not the door and see if the temps are any lower?
Thought i'd share what I have been up to this weekend!
Snow and all. Camera did take a dive seems like. But U found your camera.
What ride? Could not tell from camera location.
Thanks man. RGone...
You ran prime at 4.5 with the specs from post 51? Try giving the Cpu-V Core a bump up and see if it helps. What were the temps at, same as post 51?
As far as the sabertooth goes I feel it's overpriced, there are plenty of less expensive boards that are as good. It's a little gimmicky in my opinion. Personally I was happy with my EVO I just needed another board for another pc I was building and found the CHV in the classifieds for a good price.
As far as your pc locking up, whether it is prime stable or Aida64 stable you still need to find stability. If it is locking up using everyday tasks then it's not stable.
I think you need more Vcore to get it stable
Stock setting is 1.44 range
Still locking up even at 4.4ghz. I'm a little stumped.
Okay let me see if I can remember this 'crutch' I used to use.
1. > P95 Blend > Crash and computer need to restart = Voltage too low. This can be a Vcore setting issue WAY-OFF or it can be power supply issue.
2. > P95 Blend > Simple crash of program no reboot = Most likely not enough Vcore.
3. > P95 Blend > Program freezes = For me it means I am getting closer on settings and I need normally a little more Vcore.
4. > P95 Blend > workers dropping out = Normally a shade more Vcore.
5. > P95 Blend > workers dropping out = IN a very few instances I have had to up the CPU_NB voltage but it is not often.
6. > P95 Blend > 'FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.' = Is considered by most to be some sort of Ram problem. Could be wrong settings for the ram including speed, timings and voltage. IN a very few instances it might be the CPU_NB frequency is not fast enough but it is not often.
Those are only the 6 types of situations I have found myself in when using P95 Blend over the last 10 years or so. It is not by any means all inclusive. Probably cannot even be agreed upon by all. But I think along those lines based on what P95 Blend does on my configurations.
RGone...
I agree he may need more V Core but remember every chip is different cowboy. I run 4.5 stable at 1.375, 1.39 under load prime stable.I think you need more Vcore to get it stable
